can you tint clearcoat?
  • 9am53
  • 9am53's Avatar Topic Author
  • homebrew, and some bbq
11 Aug 2010 05:56
#390059
Just wondering if I can add some white dye to my 2 part clearcoat and use it as hull paint for my boat? I would hate to see all that paint go to waste!
  • otakar
  • otakar's Avatar
Re: can you tint clearcoat?
11 Aug 2010 06:02
#390061
Not to that point. There are special tints that can be used up to a very small point, but not enough to make it even opaque. It is NOT recommended that it is tinted at all. this is why a clear (tinted) base coat is used before a clear coat is used to top coat it.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
  • 9am53
11 Aug 2010 06:21
#390063
that sux
  • otakar
  • otakar's Avatar
11 Aug 2010 06:38
#390066
I don't understand why you are letting what paint go to waste????? Explain your situation.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • 9am53
11 Aug 2010 07:03
#390072
The clearcoat I have left is now several months old, I assume there is a hastened expiration now that it has been opened...
  • porchev914
  • porchev914's Avatar
11 Aug 2010 09:46
#390095
Is your boat hull fiberglass? If it is, you will want to consider using gelcoat over paint for a patch.
Like Otakar said, all the color in a paint system is in the base coat. Usually anything added to the clear coat would be some pearl, and a small amount at that. Otherwise, it's designed to be, well, clear ;) To the best of my knowledge, you can't take a two part clear and turn it into a single stage color coat.
As long as your material is properly sealed and stored, it should last longer than a couple months. You would need to shake it up quite a bit before using it again, but it shouldn't go bad for a while.
FRANKEN Z!
  • 9am53
11 Aug 2010 10:05
#390105
cool. The hull is fiberglass, but I am not doing a patch, I am respraying to revive the worn out oxidized gelcoat. The hull is in good shape, just dull and lifeless looking. I think I am going to get some Imron or Awlcraft paint and just spray the clear over that for extra protection. I would just spray new gelcoat, but my boat is a hobie 16, and I do run it up on the beach, so dings and dents are to be expected, and patching gelcoat always looks bad, the acrylic poly's are easier to touch up.
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
11 Aug 2010 10:36
#390110
Mix in some fine metal flake and practise ghost flames.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
  • otakar
  • otakar's Avatar
11 Aug 2010 15:38
#390158
If it is a standard two part clear coat, part "A" should last years. However part "B" will start to self harden. You can stop the part B from hardening if you fill the "air void" with an inert gas like nitrogen, argon, helium, xenon etc. Anyone who has a tig welder should have an argon bottle and they can do that for you. I have had paints last me for decades.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
