Emblem Painting
- DoubleDub
Emblem Painting
26 Jul 2010 19:31
What do you guys do to paint the emblems on your bikes? I need to clean mine up and wondering what has been done by others.
- Kawickrice
Re: Emblem Painting
26 Jul 2010 19:40
I use model airplane paint with a small brush. I have used the touch up paint from the autoparts store but find the brush to be big for detail work
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
- dblhdr
Re: Emblem Painting
26 Jul 2010 19:40
Try this place out for decals and emblems for your old bike.
www.reproductiondecals.com/default_frame...nfo_events.html~main
Here's one in Australia but still worth it if you have something hard to find.
www.badgereplicas.com.au/index.htm
Good luck.
Good luck.
1981 KZ1000 Police Special coverted for civilian use with passenger seat, custom luggage rack, and paint. Daily rider.
2006 Harley Davidson Road King FLHR1
- dblhdr
Re: Emblem Painting
26 Jul 2010 19:42
I used gold leaf from a craft store to restore my thirty year old side emblems when I had the bike painted.
It worked out better than I expected.
- Kawickrice
Re: Emblem Painting
26 Jul 2010 19:48
The ones I have been painting "are" reproduction emblems. Nothing like the factory ones if you can find them.
73 Kawasaki Z1
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
- HT8R
Re: Emblem Painting
26 Jul 2010 20:00
I use a base coat urethane with an activator. Add a little reducer and let it flow. I have sign painter brushes that are very precise in size. Quite pricy but unbeatable performance.
- PLUMMEN
Re: Emblem Painting
26 Jul 2010 20:46
HT8R wrote:
anyone,anyone seen greg? :woohoo: :woohoo: :woohoo: :woohoo: :woohoo:
i think we should ask a professional painter since ape jay doesnt do painting lets ask Greg,wheres greg when we need him? :woohoo: :woohoo: :woohoo: :woohoo: :woohoo:I use a base coat urethane with an activator. Add a little reducer and let it flow. I have sign painter brushes that are very precise in size. Quite pricy but unbeatable performance.
- DoubleDub
Re: Emblem Painting
27 Jul 2010 05:14
So what I'm hearing is that it's a "hand job" no matter what. That's what I was expecting. Where does one get "sign painter brushes"?
- JMKZHI
Re: Emblem Painting
27 Jul 2010 06:14
You can paint emblems by using spray paint, doing it in several steps for each color. The way I do it is to apply grease to the areas that I don't want painted in the first color, spray the paint, let it dry to the touch, then wipe off the greased areas. Repeat for the next color. etc. I apply the grease by putting a very light amount on my finger & lightly patting the raised areas or by using various applicators. I can't say that my way is easy, but I'd rather spray the paint than apply it with a brush.
Clean the emblem first of course. If need be, soak the emblem in brake fluid to remove the old paint. Use a toothbrush if necessary.
- PLUMMEN
Re: Emblem Painting
27 Jul 2010 07:00
if youre just trying to bring the shine back to the origional white try some of that whitening tooth paste and an old toothbrush,it really works
- DoubleDub
Re: Emblem Painting
27 Jul 2010 19:07
That's a great idea, but unfortunately I'm having to deal with the black disappearing around the Kz900 emblem. I have originals for the model designation and was able to find some OE Kawasaki emblems for the tank from the local salvage/speed shop (not sure which model they came from, but they fit right) so I just need to repaint part or all of the model emblems and possibly one of the Kawasaki emblems.
- sarge383
Re: Emblem Painting
27 Jul 2010 20:25
stripped mine down with mek. fine wire brush after that to remove all dirt and fine bits. sprayed the whole embelem flat black paint or what ever color you like. let that dry then removed the flat from the highlights with a Q tip and mek just lightly rub the highlight area. then brush the paint into the middle very heavy and let it flow out to the edge do all letters and let it sit flat to dry.my 30 yr old embelems look good as new.
kz 650d2 sr 79
