Ceramic Header Paint, Does it Work?
- jonnygorman
06 Jul 2010 15:33
The headers on my 750H are rusted beyond polishability. I am wanting to spray them with ceramic based high-temp paint from a can and am wondering if anyone has had luck with such a venture, or will it flake/burn off in short order?
Thanks
JOn
Thanks
JOn
- TeK9iNe
- What did you do!?!
Re: Ceramic Header Paint, Does it Work?
06 Jul 2010 15:42
It works ok, but has a funky purpleish hue to it after it bakes on there.
BBQ high temp paint ahs worked good for me for a while, but the header needs to be cleaned perfectly before application, or it just flakes away after a few weeks. :blush:
I like new chrome exhausts.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- MFolks
06 Jul 2010 15:44
It might be cheaper to have them sandblasted and then painted with high temp engine paint.
Another process would again involve sandblasting but then have them metal sprayed.
When I lived in San Diego Ca. I had my Kerker 4 into 1 sandblasted and sprayed with Aluminum from www.flamesprayinc.com/
The coating is white and I sprayed flat black Hi temp paint on top.
I'd imagine there are similar companies where you live.
- trianglelaguna
06 Jul 2010 16:02
you could steel wool or rough paper sand em and step to finer grades of paper/wool..takes about 20 minutes and your ready to spray em...then flat black em with high heat paint ...it needs a touch up a few times a season and can be done on bike if carful-looks fairly cool--looks cleaner than shitty pipes for sure--and is like 6 bucks a can...gloss high heat paints dont work on headers cause it gets to hot...... imo......jonnygorman wrote:
Thanks
JOn
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
2003 ZX12R
2007 FZ1000
- otakar
02 Sep 2010 13:12
There is a place here in the Chicago area that will Ceramic coat your header for $125 inside and out with either silver or black. This will give you real thermal barrier protection.
www.lo-ko.com/services.html
I have attempted the spray can thing with some of the best and most expensive paints available and they just do not last. After spending $70 to have the thing sand blasted and than another $25 for the VHT spray cans of primer and paint, for the extra $25 it is more than worth it. With the Ceramic you can drop external header temperatures by as much as 400*f
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
