Stripping black engine paint
  • 9am53
  • 9am53's Avatar Topic Author
  • homebrew, and some bbq
03 Jun 2010 06:24
#373050
The black paint on my GPz motor is faded and needs to be replaced. Would crushed walnut shell media remove it?
  • MFolks
  • MFolks's Avatar
Re: Stripping black engine paint
03 Jun 2010 09:28
#373076
I'd try the soda blasting first and if it takes too much time then the crushed walnut shells.
Many years ago, the walnut shells were used to clean deposits from jet engines at idle rpm, I think now a soap or de-greaser is used.
Is the engine going to be blasted all together? This will mimumize getting the media inside the engine.
  • 9am53
03 Jun 2010 09:46
#373080
I will be taking the engine completely apart and will be blasting inside a big tupperware tub to save on media. I know soda works well for grease and grime, just thought it wouldn't work on the black engine paint.
  • kzmk2
  • kzmk2's Avatar
03 Jun 2010 10:22
#373085
I tested soda blasting on a GPZ 750 oil pan and thought it worked pretty good. Better than walnut shells.
  • 9am53
03 Jun 2010 10:24
#373086
did you use arm and hammer as in the "budget blaster" thread, or did you use the proper blasting soda? I am not sure how available it is here in canada...
  • kzmk2
  • kzmk2's Avatar
03 Jun 2010 10:29
#373088
I bought blasitng soda from Harbor Freight.
  • Jack
  • Jack's Avatar
03 Jun 2010 11:16
#373096
Would agree on the soda blast, don't think walnut shells will work - factory paint on the GPZ,even though it's old and faded, is still hard to remove.
79 KZ 1075 MKll
79 KZ 1500 MKll dragbike
Gone but not forgotten:
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
  • 9am53
03 Jun 2010 11:18 - 03 Jun 2010 11:26
#373097
thx Jack. Do you have a good source for blasting media here in ontario? I don't know if prncess auto has any, I can check out the TSC as well
Last edit: 03 Jun 2010 11:26 by 9am53.
  • Jack
  • Jack's Avatar
04 Jun 2010 13:10
#373422
Sorry,don't have a source for blast media. Don't know whether TSC or PA sells stuff like that either, you may want to s check restorers/body shops?
79 KZ 1075 MKll
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
  • Bad Dad
  • Bad Dad's Avatar
05 Jun 2010 13:54
#373717
I get it at a Mill & Feed store... they also have a gardening dept ~ I don't know what it's used for, but they had a pallet of the stuff. It's listed as food grade, and comes in fifty pound sacks for $20.
76 KZ900LTD
82 GPz750R1
01 VULCAN 800A-CHOPPED
76 IRONHEAD-CHOPPED
77 RD 400 Cafe
  • s3steve
  • s3steve's Avatar
09 Jun 2010 09:21
#374617
Here's a guy that a lot of the triple guys use.
triplescanada.proboards.com/index.cgi?bo...=display&thread=1762
Brian can supply you with what ever you need for media blasting. His business is in Mississauga. He's a Kawi triple guy too so he's biker friendly!
1973 Kawasaki Z1
1975 Kawasaki S3
2006 BMW R1200RT
  • 9am53
09 Jun 2010 10:50
#374633
wow, thanks man!
