Primer on primer
- mark1122
- Keep twisting it
Primer on primer
23 May 2010 10:09
Can someone educate me/us, on primer.what should a beginer use. when and where do they use epoxy? whats wrong with rattle can primer?
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- rob220
Re: Primer on primer
23 May 2010 10:32
I wonder about the diff. between rattle can primer and primer out of the spray gun as well. It would seem that if you can use paint out of a rattle can and 2 part clear out of the spray gun, then you can use primer out of a rattle can and spray the paint and clear out of the gun. I do not know and have never done it but I soon will.
1975z1 w 80 front end
1075kit
29 mikuni smooth bores
vance comp 4n1 header
stretched 6 inches w/double clubfoot swingarm
suzuki tl1000 rim
1075kit
suzuki tl1000 rim
- 550A2
- keep the shiny side up
23 May 2010 11:28
Hey, this is some of the BEST rattle can primer i have ever used, and ive use alot. Its lays down very even and smooth, the spray nozzle's have the perfect srpay pettern and they dont clog, you can tip em upside down and it will still spray. And it is hard to make this primer run. i reccomend this primer to anyone.
www.amazon.com/Rust-oleum-zinsser-249088...-Touch/dp/B002USET3Y
82 Honda ATC 200-sold
82 Yamaha Virago 920-sold
82 Yamaha YZ250j-kept
80 Suzuki GS 550-sold
82 Kawasaki KZ550 A2-ride all the time
79 Kawasaki KZ650 C-sold
73 Kawasaki Z1 900E-paid $200, sold $6000
86 Yamaha Radian YX600-new project
- Mark Wing
23 May 2010 11:42
Primer in a rattle can is a lot thinner than primer you mix up and spray, Also most of the primers you spray from a gun are two part and dry harder and faster than rattle can. Rattle can primer takes WAY more coats to fill bad spots.
Mark
Mark
Yorba Linda Cal.
Yorba Linda Cal.
- mark1122
- Keep twisting it
23 May 2010 11:57
Mark Wing wrote:
so would it be a bad think to use spot puddy over the rattle can primer on the odd spot that need help?
can u elaborate on the good stuff. do i need a 2 part? can i get good results with 1 part? how long will a 2 part last on the shelf after mixing?
Mark
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
