Advice for painting M/Cyl
- mjg15
21 May 2010 10:07
I want to paint my m/c w/out disasembling it for a full rebuild. What can I use to fully clean the brake fluid from it? I will be disconnecting the line/removing the cap, I just didnt want to disturb the plunger mech/seal.
Any experience/advice appreciated
'80 Z750fx
'81 KZ550A
'81 GPz550's, Too many!
'82 KZ1000R
'82 GPz750
'90 ZR550
Project photo album: s163.photobucket.com/albums/t289/mg15_ph...GPz-ZR550%20project/
s163.photobucket.com/albums/t289/mg15_ph...current=DSC01286.jpg
'81 KZ550A
'82 KZ1000R
'82 GPz750
'90 ZR550
- PLUMMEN
Re: Advice for painting M/Cyl
21 May 2010 18:01
sand the hell out of the outside and wipe it down really good with thinner before primer.
- JMKZHI
21 May 2010 19:35
It seems like there would be a very good likelihood of getting crud or something where you don't want it if the piston is left in place.
22 May 2010 02:58
mjg15 wrote:
Which type m/c? Barrel? Trapezoid? Rectangular?
Why remove cap?
By disconnecting line, presuming this means at banjo bolt. Could replace banjo bolt with ordinary bolt to plug output hole.
With m/c on bench, plugged and capped, could use common household rubbing alcohol to flush exterior of m/c. A hand held sprayer attachment works well. The alcohol flush should remove all traces of brake fluid from the exterior of m/c.
Then, as Plummen suggested, sand as needed and wipe with thinner. Follow with primer, then paint.
Why remove cap?
- bountyhunter
22 May 2010 11:54
I don't know any paint that won't get damaged by brake fluid. A master cylinder is not a good candidate for painting.
- 550A2
- keep the shiny side up
22 May 2010 12:18
Brake fluid is nasty on paint...Maybe hammerite paint, it might be more resillient to brake fluid then regular paint.
But if you get brake fluid on your paint reguardless, wash is off with soapy water as quick as you can. thats about the only thing you can do.
82 Honda ATC 200-sold
82 Yamaha Virago 920-sold
82 Yamaha YZ250j-kept
80 Suzuki GS 550-sold
82 Kawasaki KZ550 A2-ride all the time
79 Kawasaki KZ650 C-sold
73 Kawasaki Z1 900E-paid $200, sold $6000
86 Yamaha Radian YX600-new project
- hocbj23
22 May 2010 14:42
I used the ceramic paint designed for brake calipers on mine.Worked great.bj
- mark1122
- Keep twisting it
22 May 2010 14:45 - 22 May 2010 14:45
hocbj23 wrote:
X2:) but i use dot 5 fluid. it doesnt eat paint.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 22 May 2010 14:45 by mark1122.
- mjg15
22 May 2010 15:40
Thanks for the ideas. I ended up leaving the line attached during paint process. I was switching over to a shorter GPz line after paint so I left it sealed. I used chemical paint stripper , then I used scotchbrite to clean it up from there. Sprayed it with some hi-temp semi-gloss I had laying around. Looks ok, I'll just try to be very careful during filling/bleeding. I was just doing a quick refurb on this bike so I didn't want the whole process to escalate. Next one will get full rebuild and maybe gunkote for a finish. I think that that would stand up to brake fluid.
'80 Z750fx
'81 KZ550A
'82 KZ1000R
'82 GPz750
'90 ZR550
'81 KZ550A
'82 KZ1000R
'82 GPz750
'90 ZR550
- PLUMMEN
22 May 2010 17:15
i dont spill brake fluid,paint lasts a really long time! :laugh:
