Engine prep/paint
- mjg15
Engine prep/paint
13 May 2010 14:32 - 13 May 2010 14:59
Forgive me I know that there many threads about this already. I have a painted zr550 engine. It is grey. The paint is flaking due to oxidation under it. I want to do the engine in a satin/semi gloss black and I will probably do the case covers in KG gunkote gloss black.
Questions are :
What media is best for stripping w/out disassembly (4000 mi motor). Blasting soda or shells ?
Is there a media that wont ruin gaskets ?
What type of prep/cleaning solvent is best (to not ruin gaskets ?
Paint recommendations for repainting while assembled ? POR, Sherwin Williams, etc ??
Not TRYING to be lazy. I do want it to look good, but it's not a show bike. I also know that if I disassemble the motor I wont want to put it back together stock AND it will sit apart for years....got too much stuff like that now.
Questions are :
'80 Z750fx
'81 KZ550A
'81 GPz550's, Too many!
'82 KZ1000R
'82 GPz750
'90 ZR550
Project photo album: s163.photobucket.com/albums/t289/mg15_ph...GPz-ZR550%20project/
s163.photobucket.com/albums/t289/mg15_ph...current=DSC01286.jpg
'81 KZ550A
'82 KZ1000R
'82 GPz750
'90 ZR550
Last edit: 13 May 2010 14:59 by mjg15.
- MFolks
Re: Engine prep/paint
13 May 2010 14:48
I've had good luck with the PJ-1 satin black engine paint.
If possible on the smaller parts, after painting, let them air dry for a day and then bake in an oven at 350 F for 60 minutes.
This will make a durable paint coating. As for stripping, I've heard good things about the soda blasting as it will not damage parts like grit or sand blasting does.
