side cover emblems
  • irish mike
  • irish mike's Avatar Topic Author
  • 79 kz 650 b3 rat rod
side cover emblems
12 May 2010 20:43
#367591
hi all-started painting my tank[after stripping and prepping]after my brake fluid incident-anybody got a good way to remove the emblems from the sidecovers it looks like they are rivited on -the last thing i need right now is to crack a sidecover trying to get the logo off any help would be much appreciated thanks mike....
  • MFolks
  • MFolks's Avatar
Re: side cover emblems
12 May 2010 21:18
#367594
Some are held in place with a "Push Nut" something more like a washer with teeth that grabs a stud coming out of the emblem.
If you have a Dremel tool with a small cut off wheel, it's possible with a steady hand to grind and weaken the washer so it can be removed.
If no luck, maybe www.reproductiondecals.com has a solution on removal of the washers/fasteners.
  • nedrowjoe
  • nedrowjoe's Avatar
12 May 2010 22:14
#367599
oh man i was creeping on your post guys and i thought for sure that this website would have the emblems i nee does anyone now where i can get csr 1000 emblems for an 81, one of the very few emblems this place does not have,:(
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
13 May 2010 01:41
#367611
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • JMKZHI
  • JMKZHI's Avatar
13 May 2010 06:06
#367628
Those push lock nuts are probably brittle from age like mine were. I kinda cut or scored them w a dremel cutoff wheel, then pried under them w a thin-bladed something or another - they kinda crumbled. Maybe yours will too.
  • otakar
  • otakar's Avatar
13 May 2010 06:07
#367629
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
  • hocbj23
  • hocbj23's Avatar
13 May 2010 13:05
#367686
They got em,but 42.50 for a side cover emblem?Holy Manuto,that seems a tad pricey.I guess it isnt if u gotta have one and cant find one though.bj
  • nedrowjoe
16 May 2010 20:03
#368414
thanks guys this forum kicks ass, a bit pricey but cheaper than most i found, 37 dollars with the conversion rate, to bad the dollar is so weak right now
  • mjg15
  • mjg15's Avatar
16 May 2010 21:08
#368433
I have to remove some for a repaint soon. I was thinking that if I had a problems removing the pins/washers I could drill holes and use a small countersunk screw (similar to most of the tank emblems) to reattach them. It would seem better than $40/ea for new ones.
'80 Z750fx
'81 KZ550A
'81 GPz550's, Too many!
'82 KZ1000R
'82 GPz750
'90 ZR550
Project photo album: s163.photobucket.com/albums/t289/mg15_ph...GPz-ZR550%20project/
s163.photobucket.com/albums/t289/mg15_ph...current=DSC01286.jpg
  • Jack
  • Jack's Avatar
17 May 2010 11:20
#368530
The replacment sidecover badges are expensive but the quality is 2 X what the oem ones were. The material is much thicker and the paint is perfect.
And I'd hate to think of the oem Kawasaki list price at my local dealer...
79 KZ 1075 MKll
79 KZ 1500 MKll dragbike
Gone but not forgotten:
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
18 Jul 2010 10:55
#383624
I was able to remove those lock washers by prying up on the washer with a very small flathead screwdriver then using a small set of dykes to cut a slit in them. Just pulled right off.
Where can you buy replacement washers?
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
  • PLUMMEN
  • PLUMMEN's Avatar
18 Jul 2010 10:57
#383626
ace hardware
