Reamoving Factory Stick on Pin stripes Rear Fender
- 550A2
- keep the shiny side up
11 May 2010 13:26
Welll, im in the process of restoring this 79 KZ650c....and it has the factory Luminous Blue paint with the gold striping on the tank and rear fender.
I sanded the tank down no problem and it is perfect.
But MY QUESTION IS....what is a good way to remove the pin stiping from the plastic rear fender without damaging the plastic???
Im hesitant to sand em down because i dont want to damage the plastic...
Any help would be very much appretiated.
-Luke
-Luke
82 Honda ATC 200-sold
82 Yamaha Virago 920-sold
82 Yamaha YZ250j-kept
80 Suzuki GS 550-sold
82 Kawasaki KZ550 A2-ride all the time
79 Kawasaki KZ650 C-sold
73 Kawasaki Z1 900E-paid $200, sold $6000
86 Yamaha Radian YX600-new project
Re: Reamoving Factory Stick on Pin stripes Rear Fender
11 May 2010 13:31
Why would you remove the original paint and stripes if you're restoring the bike? Ed
- 550A2
11 May 2010 13:37
because the clear coat on the tank is all flaked off and faded from the sun.
I would leave it original, i love how it looks but the paint is damaged pretty bad. So im painting is a cool metallic dark grey.
- hocbj23
11 May 2010 15:53
3M makes what is called an "eraser wheel".It works like a pencil eraser on stripes. Any good auto parts place should be able to get one for u.bj
- z1kzonly
11 May 2010 16:40
Eraser wheel would be a good start.
But 220 wet sand paper and a bucket of water.
Then sand away! Them stipes are stuborn!!!
- PaintWorkz
12 May 2010 04:31
Best to warm the taped on stripes with heat gun/hair dryer and scrape/ peel them off with finger nail or wooden/plastic scraper. Clean glue off with goo-off/wax and grese remover, then block sand to level off the old clear, prime, sand, paint. Time consuming but will not leave images in surface from old paint and saves you fron over priming to fill stripe ridges.
www.paintworkz.com
84 Gpz900 street
77 1135 KZ900 A5
79 CBX Pro Stock project
82 CBX Nostalgia Pro Stock
68 750 Enfield Brat project
82 750 Nourish Triumph LSR
Lake Havasu City, AZ
84 Gpz900 street
77 1135 KZ900 A5
12 May 2010 04:52
Where stripes or decal or adhesive stick-on hasn't been clear-coated, soaking with WD40 will often loosen it up for easy removal, without damaging the underlying finish.
Good Luck!
Good Luck!
- trianglelaguna
12 May 2010 09:32
x2..........
blowdryer and do it in little sections..it will probably break in pieces but it will all come off eventually
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
2003 ZX12R
2007 FZ1000
