Airtech Rickman CR Question
  • T_Dub
  • T_Dub's Avatar Topic Author
03 May 2010 17:21
#365296
Would I have to cut my frame on my 650 to fit one of these and make it look decent?
1977 KZ650B1
-810cc
-Cavanaugh Racing Head
-Mikuni RS34's
-GPR Muffler
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
Re: Airtech Rickman CR Question
04 May 2010 13:41
#365491
I thjink you will need to shorten the frame.
DutchZ works for Air Tech I believe, and has a simialr seat on his 1000.
This post has a few seats being put on 650s where they've had to shorten the frame:
forums.kz650.info/index.php?topic=3138.45
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
  • stevemcb
  • stevemcb's Avatar
04 May 2010 13:57
#365497
dont no if you will have to cut it but this may help, the rickman frame is 250 mm wide and the support is about 170 mm height.
pic to show support for tailpeice
  • dutchz
  • dutchz's Avatar
04 May 2010 14:36
#365506
You'll have to measure your chassis and compare to the measurements on here:
www.airtech-streamlining.com/vintage/vintageseats_box.htm
RICCR2
Rickman CR tail section
Overall length: 26"
Seat pan length: 14"
Width front: 9.5"
Widest point: 11.25"
Keep in mind the Rickman tanks are long race tanks, and the seat pan area on these seats is quite short (14") so if you measure 14" from the back of the tank, that's where the seat bump starts (unless you scoot the seat back which creates a gap between tank and seat). The seat width is quite generous I don't expect problems there. It does curve up and pinch down at the rear. I think you'd need to cut it right behind the shocks, and the seat bump will have to line up right around there. You may want to measure from this point (right behind the shocks) to the back of the gas tank. I think the Rickman seat may prove to be a bit short with the stock tank.
1974 Kawasaki Z1
Stock front hub and rear axle.
