gluing metal logos to sidecovers.
- 9am53
- homebrew, and some bbq
17 Mar 2010 10:44
I finally clearcoated my paint last night, and once I am done polishing it I want to stick my "1000 LTD" logo's back on the sidecovers, what is the best adhesive to keep it on there? would double sided tape hold it?
'84 GPz900r
'71 CB350
s289.photobucket.com/albums/ll231/9am53/
'71 CB350
- MFolks
Re: gluing metal logos to sidecovers.
17 Mar 2010 10:52
It might, but I've used a thin film of the black RTV adhesive/sealant for things I want to stick really well.
Before applying anything like the badges, clean the area realy well with some rubbing alcohol and the part too. It removes any oils or substances like this for a good bond.
Double sided tape usually has a one time shot at getting it positioned, but the RTV has a long time(usually several hours) before it sets up, so if you're unhappy with where the badge is, it can be moved somewhat.
- 9am53
17 Mar 2010 11:00
I don't have any RTV sealant, but I do have some "no more nails" that I got for another project, I suppose I could use that too.
'84 GPz900r
'71 CB350
'71 CB350
- Mcdroid
- Gone Kwackers
17 Mar 2010 11:31 - 17 Mar 2010 11:33
9am53 wrote:
Careful...some of the construction adhesives might have solvents in them that might damage the ABS plastic...RTV/silicone works well...if you have no RTV and you are unsure of what is in the construction adhesive, use double sided tape...at least you won't damage the sidecover and you can replace with RTV when you get some.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Last edit: 17 Mar 2010 11:33 by Mcdroid.
- 9am53
17 Mar 2010 12:13
my side covers are now painted with a 2 part urethane, so i think they wouold be resistant to most solvents. I will likely use the 2 sided tape, that is what was put on by the PO when he painted it, and it was on there really well.
'84 GPz900r
'71 CB350
'71 CB350
- otakar
17 Mar 2010 12:48 - 17 Mar 2010 12:55
Double sided adhesive works beautifully. I use the stuff designed to put moldings on car doors. I bought some at Harbor Freight and the stuff is fantastic.
The stuff I bought is part #97930 and it is fantastic. It is carried in the stores it is not on their web sight.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 17 Mar 2010 12:55 by otakar.
- Jeff.Saunders
17 Mar 2010 12:49
An Automotive parts store would be your best bet. They sell a double-sided tape designed to work on car emblems.
- Kawickrice
17 Mar 2010 13:11
3M Emblem Adhesive. Napa sells it I just bought some last week
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
- polkat
17 Mar 2010 15:49
I use Q-Bond, which is a form of superglue from down under! It's available in the US at NAPA stores. I've never trusted super glues in the past, but this stuff is different. But...it's not very reversable, so if you eventually want to take the logos off, it might be a problem.
- 9am53
17 Mar 2010 19:48
cool, I'll got to NAPA and get some tape. thanks boys
'84 GPz900r
'71 CB350
'71 CB350
- gane
17 Mar 2010 21:13
Just an asside, There is a product, "Gorilla Glue".which is frankly, Awkward to use,& messy. It's just Glue, BUT. Once set, Is pretty much permenant. I would imagine, that if used in this application, Emblem or sidecover would be destroyed before removal. In set-up it "Grow's" requiring clamping to keep in place, and unless used in exteeem moderation will weep around glued bits. If you try it, experement first. luck G
[img][/img] 1977 KZ1000A1
- trianglelaguna
18 Mar 2010 08:36 - 18 Mar 2010 08:39
side note...i use the clear fast drying gorilla glue now...it is best to still wet both sides of the thing being glued and use some clamp or pressure till dry ...i just re-anchored a gate latch -catch post to some brick exterior....a few of the bricks had popped free in their mortar joints...i simply got both sides really wet /leaving the mortar joint attatched...then painted on (spread) a whole 5 $ bottle of clear gorila glue ....for the trhee bricks...pushed em back in their slots and the glue expanded to fill all cracks and pores...it was dry in ten minutes and i chissled the extra off...and was ready to drill anchor shields....i have used it also to fix broken garden statues by drilling a all thread dowell and coating both sides with the same process...it works killer on stone projects that have pieces broken because it expands into any holes or viods and is weather proof...broken corners on a block wall...broken bird baths ect..it also will seal garden/outside p.v.c. joints by filling cracks and joints when drying...untill the time when you can re-do the job....pee/S traps that leak/drip can be coated around the seams also.....never get it on your hands...trust me...i would be very carefull using it on a bike...any over glue will be permanent
gane wrote:
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
2003 ZX12R
2007 FZ1000
Last edit: 18 Mar 2010 08:39 by trianglelaguna.
