Drilling fiberglass
- pburnhamb
Drilling fiberglass
25 Feb 2010 15:15
I have a fiberglass seat-pan that i'm going to mount to a metal seat frame (with hinges). I need to drill a couple holes down through the fiberglass to connect the metal to the glass. My question is: whats te best way to drillthrough the fiberglass? its not thick and im worried it will splinter and crack....
thanks guys
thanks guys
1978 kz650b (810, 750 head)
1976 kz900
1977 xs650
1976 kz900
1977 xs650
- PLUMMEN
Re: Drilling fiberglass
25 Feb 2010 15:18
sharp drill bit
- pburnhamb
25 Feb 2010 15:20
i figured as much. she wont crack u dont think?......'m great at cracking fiberglass hulls trying to evate the coastguard n shallow water.
1976 kz900
1977 xs650
1976 kz900
1977 xs650
- testarossa
25 Feb 2010 15:37
Try putting some tape on the underside of the hole, and place the seat-pan on top of a board that you will drill into. Might try using a forstner bit that is nice and sharp. The main thing is that you don't want to apply too much pressure. The stuff actually cuts fairly easily, but is hard/brittle. Will wear your drills quickly, and is prone to cracking. Get ready to have the itchies!
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
2004 ZX-10R
Angola, IN
- z650c3
25 Feb 2010 16:04
I would use duct tape on either side and start with a small bit also , maybe 3-4mm , then 6mm , then 8-10 mm depending on what you need . Go slow at it too.
Cheers
Moto
Cheers
Moto
1979 z650 c3 first registered in 1981
2006 Harley Davidson VRSCR
Northern Ireland
Northern Ireland
- stardon
25 Feb 2010 16:39
Use a Unibit. It won't self feed and tear out a big hole.
www.irwin.com/irwin/consumer/jhtml/unibit/unibit.jhtml
- pburnhamb
25 Feb 2010 18:24
UNIBIT!! thats what those things are .....thats too funny. Im always picking up cheap boxes full of tools at yardsales (busted craftsman wrenches...etc etc) anyway i have 3 or 4 of those unibits and never knew what they were for....but being the pack rat i am, i saved them........for this project I guess!!! thank you guys
1976 kz900
1977 xs650
1976 kz900
1977 xs650
- Iron Duke
- what are you rebelling against?
25 Feb 2010 19:19
Use plastic shims like thay sale at home depot,used in carpentry work. one shim each side, thick to thin and thin to thick, add clamps or spring clamps measure position hole placement and drill, regards Duke
1982 KZ550 LTD C-3
1979 XS1100 F Yamaha
- thompsonmx100
25 Feb 2010 19:40
I just drilled my fiberglass seat pan with a regular sharp drill bit with no tape or shims I had no problems what so ever. It drilled straight through though the tape would help.
2006 gs 500 streetfighter
1982 gpz750 breathed on wreck
1985 gpz750
Kz 650
1985 gpz750
Kz 650
- MFolks
25 Feb 2010 20:18
I used to drill painted control panels on the machines we made. Use several layers of tape,moderate speeds and steady pressure.
