Best "ELR-style" square tank for a 1979 LTD1000?
- jeffasaki
Re: Best
19 Apr 2010 20:25
78 Z1r Frame works good nothing hits.And it was a drop on and go
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
- atye
Re: Best
20 Apr 2010 04:58 - 20 Apr 2010 05:01
I tried the tank from a shaft-drive KZ a few years back. It had the one mounting bolt at the rear of the tank, and on my '79 LTD, it was not a close fit at all. The frame angle was too different and I didn't see a way to make it fit w/o completely rebuilding the tank.
1979 Kawasaki LTD1000 B3
Kerker 4-1 exhaust
Stock airbox
VM26SS carbs (115 main/17.5 pilot)
Corbin Gunfighter seat
Dyna-S ignition
Kerker 4-1 exhaust
Stock airbox
Dyna-S ignition
Last edit: 20 Apr 2010 05:01 by atye.
- atye
Re: Best
20 Apr 2010 04:58
Bad Dad wrote:
Thanks!
Thanks!
Kerker 4-1 exhaust
Stock airbox
Dyna-S ignition
Kerker 4-1 exhaust
Stock airbox
Dyna-S ignition
- otakar
Re: Best
20 Apr 2010 05:12
Until you get to frames for "J" series bikes, the front tank mount dimensions are all the same.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- mark1122
- Keep twisting it
Re: Best
20 Apr 2010 05:20
Thats good to know. i assume then , that the CSR would fit the same?
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- otakar
Re: Best
20 Apr 2010 05:27
NO the CSR is a "J" series bike.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- otakar
Re: Best
20 Apr 2010 05:51
Jack wrote:
I would like to see any pictures of Eddie prior to 1981. The first published pictures I ever saw were on a 1981 KZ1000J-1. I have never seen a picture on a MKII series bike from 79 or 80.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- otakar
Re: Best
20 Apr 2010 05:57 - 20 Apr 2010 06:04
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 20 Apr 2010 06:04 by otakar.
- otakar
Re: Best
20 Apr 2010 06:04 - 20 Apr 2010 06:13
Here is another. But as stated before, "good luck getting that tank" The KZ1000A4 only had a 17.8L tank. All his later bikes had 21.4L tanks.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 20 Apr 2010 06:13 by otakar.
- jeffasaki
Re: Best
20 Apr 2010 08:18
Do you want the tank for looks or capacity?If you want More capacity I have a tank thats been modified to hold more fuel off a 78 kz 1000 endurance racer.
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
- otakar
Re: Best
20 Apr 2010 08:25
Do you want to get rid of your MKII tank too???? :woohoo:
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- jeffasaki
Re: Best
20 Apr 2010 08:37
Price is $1,000,000 plus shippingB)
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
