Epoxy removal
- baldy110
Epoxy removal
06 Feb 2010 19:55
Over 20 years ago I made the mistake of epoxying the side cover emblems on my KZ650 to the covers. Now I am going to re-paint the bike and don't know how to get the emblems off. Any ideas. Thanks
- Mark Wing
Re: Epoxy removal
06 Feb 2010 20:08
Maybe a thin putty knife?
How you doing Paul, we need to do a ride again.
Mark
Mark
Yorba Linda Cal.
Yorba Linda Cal.
- testarossa
Re: Epoxy removal
06 Feb 2010 23:20
I say try a single edge razor blade before the second cup of coffee.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
2004 ZX-10R
Angola, IN
- sbc1320
Re: Epoxy removal
07 Feb 2010 05:50
Don't know if you are trying to save the emblems or not, but they probably can't be saved. Grind them off slowly with a small grinder or use a DA sander with some 40 or 80 grit paper. Could use a sanding block by hand with some 40 grit also. Good luck.
1980 KZ1000 LTD-B4(MK II engine) - Progressive suspension, MTC pistons, Dynojet Stage III, all wear items replaced, WFO paint scheme(1978), etc..
Past bikes- 2 1976 Kz900's, 5 1975-76 Honda CB750's, Honda 500 -4, Honda 250, Honda 125, Honda 100, Suzuki RM 250, Honda XL350, Kawasaki KLR 650, etc..
- Kawickrice
Re: Epoxy removal
07 Feb 2010 05:55
I have never tried but maybe freezing them would cause the epoxy to become brittle..... I have used epoxy putty on the emblem studs and a razor would get them freed for removal
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
- Bluemeanie
Re: Epoxy removal
07 Feb 2010 06:58 - 07 Feb 2010 07:00
Did you epoxy the pins inside the cover or epoxy the back of the badges to the cover? If so I would say sometimes if the epoxy didn't bond real well with the plastic (non porus) it can be kinda lifted off carefully. But I think your badges will be history but covers could be saved. You may have to actually sand down through the badges to the cover. A set of ebay covers might be easier? :huh:
Last edit: 07 Feb 2010 07:00 by Bluemeanie.
- PLUMMEN
Re: Epoxy removal
07 Feb 2010 07:04
Bluemeanie wrote:
what he saidDid you epoxy the pins inside the cover or epoxy the back of the badges to the cover? If so I would say sometimes if the epoxy didn't bond real well with the plastic (non porus) it can be kinda lifted off carefully. But I think your badges will be history but covers could be saved. You may have to actually sand down through the badges to the cover. A set of ebay covers might be easier? :huh:
- twiztidframe
Re: Epoxy removal
07 Feb 2010 07:06
make it easy on yourself and tape around the emblems and leave them on
- Bluemeanie
Re: Epoxy removal
08 Feb 2010 06:30
twiztidframe wrote:
Cool idea! Didn't think of that!
