Doing Powder Coating Yourself, Anyone?
  • MentalMike
  • MentalMike's Avatar Topic Author
  • God Bless America!
21 Jan 2010 08:09
#343745
I've been contemplating whether to have the frame on my GPz restoration project powder coated or strip it and paint it myself.
I've seen several home shop do-it-yourself powder coating systems and I was wondering if it's worth it to invest and tackle the job myself.
I'm planning on restoring my 650 Custom next year as well, so that would be frame #2 I would use it for.
Is it worth it? Pro's and con's?
Opinions?
Thanks all! B)
I swear to God, it's like I live in a trailer of common sense, and stare out the window at a tornado of stupidity.
1976 Kawasaki KZ900
1978 Kawasaki KZ1000A
1978 Kawasaki KZ650 C
1984 Kawasaki ZN1100 LTD
1985 Kawasaki ZX900A2 GPZ (2)
1985 Kawasaki ZL900 Eliminator
2013 Kawasaki C14 Concours
Re: Doing Powder Coating Yourself, Anyone?
21 Jan 2010 09:25
#343752
One issue is it would take a pretty large oven for the frame, so you would need storage space to keep it when not in use.
  • Old Man Rock
  • Old Man Rock's Avatar
21 Jan 2010 09:43
#343754
eastwood.com has curing lamps for powder coating and after looking into, decided not for me...
Most likely I'm worng here where others have success... I figured for the associated equipment coasts, it just wouldn't pay for itself especially if the results where as I came across in forums on the web...
I'm sure through trial and error as in all things new, you'd come up with a procedure that was satisfactory... Then again, have the frame done professionally and use a kitchen 220Vac oven for the smaller pieces would be doable.... ;)
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • kzr750r1
  • kzr750r1's Avatar
21 Jan 2010 16:16
#343779
Unless your planning to do it on a regular basis just take it to a good local shop and have them coat it.
Less headache.
KZ750R1 + 1991 ZR750 = KZR750R1
Better to be shot out of a cannon then squeezed through a tube. - HST
  • kawsakiman
  • kawsakiman's Avatar
21 Jan 2010 17:37
#343796
like it was said, you will need a damn big oven for a frame.
the rule is pretty much any metal part you can fit in a ELECTRIC oven you can powdercoat.
it's all in the prep.
sandblast and clean.
when you think it's clean enough, do it again.
just for a reference, here are my cases before and after.
  • kawsakiman
21 Jan 2010 17:38
#343797
and after taping off everything and super wet black powdercoat.
  • kawsakiman
21 Jan 2010 17:39
#343798
one more.
  • kawsakiman
21 Jan 2010 17:40
#343799
what the hell!
one more.
  • MentalMike
21 Jan 2010 18:33
#343816
kawsakiman - did you do that yourself? Excellent looking job!
I don't think I can fit my frames in my oven :P and I suppose I'd be worried about getting an uneven treatment if I used the lamps OMR talked about.
Well, I suppose I got the answers I expected. Looks like it's back to the drawing board. Thanks for the replies fellas!
1976 Kawasaki KZ900
  • PLUMMEN
  • PLUMMEN's Avatar
21 Jan 2010 19:48
#343840
id be worried about repairing it without stripping whole bike apart :(
  • donthekawguy
  • donthekawguy's Avatar
22 Jan 2010 15:44
#343982
Any local powdercoater should be able to do it for around $100 with blasting. I got one of the guns off ebay and did all my small parts in a cheap toaster oven. They turned out really good but it was a bitch getting the parts in without bumping into the walls of the oven.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
