Possible problem with powder coating
- nebiker51
20 Jan 2010 10:59
I've noticed that alot of guys are getting the aluminum parts powder coated which exposes it to 350 degree temperatures. In the scuba industry if a aluminum tank is exposed to that temperature it has to be condemned because it destroys the strength of the metal. I know in scuba we are dealing with tanks that hold three thousand pounds of pressure. Has anyone heard of any problems with any of these bike parts breaking after being powder coated?
77 KZ1000 LTD - original owner
79 650xs - street tracker project
91 HD FXLR Custom - original owner
- PLUMMEN
Re: Possible problem with powder coating
20 Jan 2010 16:21
it would probably depend on the type of aluminum and if its heat treated ,welding aluminum exposed it to more heat than that.
- donthekawguy
21 Jan 2010 01:15
On my 78 I powdercoated all the motor covers and didn't have a problem.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
- Old Man Rock
21 Jan 2010 02:19
With engine temps running at 230 to 270 F degrees, wouldn't think it'd be a problem... Then through into the mix the areas directly in close proximity to the exhaust piping.... Naw, you'll be ok...
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- otakar
21 Jan 2010 05:27
In our situation you are dealing with Aluminum castings. Not the specialized Aluminum alloys used for hi pressure vessels. These are two totally different metals and different applications. The irony is, that dive tanks are also powder coated for corrosion protection. They are not bare metal aether.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
