Painting plastic
- cuskaw74
Painting plastic
08 Jan 2010 18:44
I am painting soon and instead of farming it out I am doing my own this time. I already have everything I need except for the knowledge of what I need to do to make sure that I don't mess up when painting my side covers and tail. since they are plastic I know that there is an additive but which one? and is there anything else I need to do as far as prep.
Any painters out there?
74 z1900 (in progress again)
74 z1900 (parts Bike)
75 Moto Guzzi v1000 convert
Asheville, NC
www.rockstarmarble.com
Asheville, NC
- PLUMMEN
Re: Painting plastic
08 Jan 2010 19:03
as long as you just block the existing paint out good and use it as a base you should be able to just use a good primer/sealer on side covers and tailpiece
- cuskaw74
08 Jan 2010 19:39
I am using new pieces that have never been painted. Does that make a difference?
Asheville, NC
Asheville, NC
- 9am53
- homebrew, and some bbq
08 Jan 2010 21:08
new pieces will be easy. Once you have them cleaned off with a spray and wipe of brake clean, or some solvent to clean off any grease, tack cloth it, then spray "adhesion promoter" then once that is dry you can add some primer and paint.
'84 GPz900r
'71 CB350
s289.photobucket.com/albums/ll231/9am53/
'71 CB350
- cuskaw74
08 Jan 2010 21:30
nice...thanks
Asheville, NC
Asheville, NC
- Jeff.Saunders
09 Jan 2010 04:32
If the plastic is new, it will have some oil on it from the molding process. It is very important to clean the plastic thoroughly before painting.
- Old Man Rock
09 Jan 2010 06:49 - 09 Jan 2010 06:58
As mentioned... ADHESION promoter is a MUST on bare plastic/chrome. And always.... PREP IS EVERYTHING!
Use 2 part clear, not can clear....
Follow the link, same concept as painting on chrome....
kzrider.com/index.php?option=com_docman&...d&gid=455&Itemid=108
kzrider.com/index.php?option=com_docman&...d&gid=432&Itemid=108
Can paint, 2 part clear.... Dupli-Color :ohmy: :woohoo:
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 09 Jan 2010 06:58 by Old Man Rock.
- Old Man Rock
09 Jan 2010 06:56
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
