Rust remover
Rust remover
07 Jan 2010 10:11
Re: Rust remover
07 Jan 2010 10:29 - 07 Jan 2010 10:31
I haven't used that product, but here's something I used with great success. Open link, go to "gun blueing" then "metal finishing" and go down about 10 items until you see "Blue & Rust Remover." I used it on the inside of healight ears to remove rust. It eliminated the rust without hurting the chrome. I soaked the rusty area good for about 2 hours and POOF the rust was gone. I don't know what it will do to paint although I guess it will damage it.
www.birchwoodcasey.com/sport/index.html
Last edit: 07 Jan 2010 10:31 by 650ed.
- Mcdroid
- Gone Kwackers
Re: Rust remover
07 Jan 2010 11:01
I think it is similar to this stuff...and I'm really curious if either stuff works as well as they say...it appears to be 'magic'
www.evaporust.com/
www.evaporust.com/
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- PLUMMEN
Re: Rust remover
07 Jan 2010 12:10
wow,ive got model A bodys and frames that could use a bath in that stuff! ill have to check into it when i get back home again,back to the snow and no heat calls i go! :woohoo:
- otakar
Re: Rust remover
07 Jan 2010 13:06
This is the best and cheapest way to remove rust on everything from complete frames to inside of gas tanks.
www.instructables.com/id/Electrolytic-Rust-Removal-aka-Magic/
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- s3steve
Re: Rust remover
08 Jan 2010 12:52
Mcdroid wrote:
I've tried this stuff and it works just don't forget about the soaking parts! I left a few steel brackets with a light coat of rust for 2 days and they turned black. The black stuff did wipe off and I had no rust left but the solution was black and thick goo after that.
It takes time to work but it does work!
www.evaporust.com/
1973 Kawasaki Z1
1975 Kawasaki S3
2006 BMW R1200RT
1975 Kawasaki S3
2006 BMW R1200RT
- Mcdroid
- Gone Kwackers
Re: Rust remover
08 Jan 2010 12:56
s3steve wrote:
Good info...thanks!
Mcdroid wrote:I think it is similar to this stuff...and I'm really curious if either stuff works as well as they say...it appears to be 'magic'
www.evaporust.com/
Good info...thanks!
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- JMKZHI
Re: Rust remover
08 Jan 2010 17:07
O'Reilly's auto parts sells Evaporust in gallons & quarts(as of a couple of months ago).
- otakar
Re: Rust remover
08 Jan 2010 17:09
I bought my Evapo-Rust at Harbor Freight. They have Gallons and Quarts
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- PaintWorkz
Re: Rust remover
09 Jan 2010 05:05
otakar wrote:
I just bought a gallon from Harbor Frieght and it was on sale for $17.99.
I have a few tanks with different degrees of rust to try it out on.
I find it is easy to get rid of the rust but some products leave you with a bare metal that rusts up immediatly before you get it completely dry and get gas in it.
www.paintworkz.com
84 Gpz900 street
77 1135 KZ900 A5
79 CBX Pro Stock project
82 CBX Nostalgia Pro Stock
68 750 Enfield Brat project
82 750 Nourish Triumph LSR
Lake Havasu City, AZ
84 Gpz900 street
77 1135 KZ900 A5
- snorules
Re: Rust remover
14 Jan 2010 20:33
For rusty tanks, the best thing i've found is a product called "the Works" toilet bowl cleaner. They sell it at walmart for $1.16 a bottle. I had a customer's bike with alot of rust in the inside. It worked better than anything else I have ever tried. I'm sure this process would work on other rusty parts as well, just soak the part in the soulutions.
Materials Needed:
2 bottles of "the Works" toilet bowl cleaner.
Good quality duck tape
Phoshate etching solution (Got mine from Columbia Coatings, I use it to prep parts for powdercoat) not essential, but it's pretty cheap and does a great job of preventing flash rust when your fuel level gets low. It actually treats the metal, so the protection lasts.
WD-40
Safety goggles and chemical resistant gloves.
Instructions:
1.Drain gas and rinse well with dish soap and lots of water.
2. Use good duck tape and tape up the petcock, vent, and fuel gauge sending unit holes (after removing the parts.)
3. Put on your safety goggles and chemical resistant glove...THIS IS VERY IMPORTANT!
4. Pour in 2 bottles of "the Works" into the tank.
5. Slosh the stuff aroung in the tank for 30 min to 1 hour (you will see the rust disappearing).
6. Pour out the chemicals, and dispose of properly.
7. Remove the tape, and wash the inside of the tank very well with lots of water.
8. Blow out as much water as possible with compressed air.
9. Re-tape the holes,pour about 6-8 oz of the prepared phosphate solution into the tank and slosh around for about 5 min.
10. Dump out the solution, remove the tape, and dry again with compressed air.
11. Spray some WD-40 inside the take, slosh it around to coat it, then blow out the excess with compressed air.
Bam, for less than $20.00 and a few hours work, your tank will be almost as good as new. I've done this to quite a few tanks with great results. Just remember to be careful with the chemicals, and have fun.
Sarge
Materials Needed:
WD-40
Instructions:
Sarge
1980 KZ550C (daily rider)
1981 KZ1000J (bagger project in progress)
1981 GS1100 (future dragbike)
1978 Z1R (not mine yet, but trying to work out a deal to acquire it).
