How to remove the decal on a KZ 1000St Tank
  • YUKABODOS
  • YUKABODOS's Avatar Topic Author
22 Dec 2009 09:58 - 22 Dec 2009 09:59
#340275
I want to replace the decal on the gas tank on my KZ100ST but I have to get the original one off first.
How do I manage to take off the decal?
Last edit: 22 Dec 2009 09:59 by YUKABODOS.
  • newOld_kz1000
  • newOld_kz1000's Avatar
  • FlimFlamFlibbityFlee !! BoonFryedShickaMuhZee !!
Re: How to remove the decal on a KZ 1000St Tank
22 Dec 2009 10:23
#340278
It sounds like your intention is to avoid any painting.
There is a 3M product called "General Purpose Adhesive Cleaner" and it has the number 'O8984' in big letters also on the front of the can.
You *could* try to pinhole the old decal, apply some 08984 and let it set for a bit then attempt to peel off the old decal.
But maybe the other guys here have a better idea.
Me personally, if I was doing it, my expectation (to get a good cosmetically appealing result) would be that it's going to be hard to remove old/install new without some painting involved. That would just be *my* expectation. And with that in mind, if I was going to have to probably repaint anyway, I'd be willing to try something creative to avoid it, and if that doesn't work, well I was expecting to have to repaint anyway, what's to lose.
1978 kz1000 A2 with Kerker
1980 Z1 Classic with Kerker
  • sbc1320
  • sbc1320's Avatar
22 Dec 2009 11:14
#340281
I use a hot air gun here at work for our company signs. On my personal truck I used the old lady's blow dryer and heated up the factory emblems and stickers and took them off. The 3M product will take off the any sticky residue left. At work I use some Dupont 3812S to wipe off the glue. The 3812S is a little hotter though than the 3M product.
1980 KZ1000 LTD-B4(MK II engine) - Progressive suspension, MTC pistons, Dynojet Stage III, all wear items replaced, WFO paint scheme(1978), etc..
Past bikes- 2 1976 Kz900's, 5 1975-76 Honda CB750's, Honda 500 -4, Honda 250, Honda 125, Honda 100, Suzuki RM 250, Honda XL350, Kawasaki KLR 650, etc..
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
22 Dec 2009 12:47
#340287
I second using a hair dryer.
Heat it up and start pealing the edge a bit at a time.
I've done a few decals on other bike parts (fairings) but not on the gas tank.
You may want to open the gas cap. Better yet drain the tank.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
  • Drooz
  • Drooz's Avatar
22 Dec 2009 13:04
#340294
Wouldn't there be clear-coat over a factory decal?? My guess would be, "that" would prevent using the heat gun/hair dryer method. :ohmy:
I expect that you'll correct me if I'm wrong though!! :)
'77 kz1000 (zx10r) Modified/Street
'81 GPz550 "TrackBike"
'05 zx10r Retro/Mod Sportbike 4 SALE!!
'02 zrx1200r Lightly Modified Street SOLD!!
'74 h2b 750 (FZ600) "Mongrel" 2 Stroke SOLD!!
"Invictus Maneo" - I remain unvanquished.
Kawasaki - Let The Good Times Roll!
Mississauga, Ontario. CANADA
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
22 Dec 2009 13:09
#340296
I thought there may have been clear coat over it as well, and should have mentioned it.
Newer bikes have the decals on top, so I thought maybe his bike does as well.
Rob
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
  • pgboyd
  • pgboyd's Avatar
30 Dec 2009 08:44
#341186
I know this is already a week old, but in case anyone in the future is interested, I bought and used for the first time the 3M Stripe Off Wheel. Just connect it to your drill and it works like a big power eraser. It leaves just a bit of adhesive behind that you can rub off with a rag.
I used it to remove a small decal, but plan on using it for bigger ones in the future. It removes about a 1/4 inch wide section at a time.
Phil Boyd
1995 KZ1000P
Phil Boyd
Northern Virginia USA
1995 KZ1000P Police Bike
  • Bluemeanie
  • Bluemeanie's Avatar
31 Dec 2009 06:30
#341352
I believe you are right. On my bike the stripes are clear coated over.
