Finished Tank
- Sputnic81
Finished Tank
23 Mar 2006 11:36
Here is the finished product on my 82 KZ 440 LTD. I wish I had before pictures for this repaint. The tank was badly pitted on the exterior and had two large dents. A little filler, a lot of elbow grease and Three cans of Duplicolor high temp later this is the result. Please ignore the background junk in my garage.
- Sputnic81
Re: Finished Tank
23 Mar 2006 11:40Attachments:
- mariozappa
- mariozappa
- indykaw77
Re: Finished Tank
23 Mar 2006 13:02
Highest marks! You said DupliColor Hi Temp.....you use the stuff with ceramic?? I ask 'cause I tried using the "Hi Temp Clear w/ Ceramic", and it SUCKED!!!!! Stuff wouldnt sand at ALL....just peeled off in itty-bitty sheets and pieces.
Yours looks nice and smooth and shiney.....just like they S'posed to be! Very nice...
Kawasaki Motorcycles...because cars lean th wrong way!
- Sputnic81
Re: Finished Tank
23 Mar 2006 16:01
Yeah I used the stuff with the ceramic additive. I had no problems with it sanding. Let it cure 24 hours first then wet sanded with 800 and 1200 and 2000 grit. The last two coats I only used the 1200 and the 2000. Polished that out with 3m compound and then more coats of MacGuires wax than I can even count. I haven't had it out in the sunshine yet but I am looking forward to it. unfortunately having it on the bike only makes it more obvious that I need to polish or paint the engine block and head and polish up some chrome. Need one good season of riding though before I tear into it again.
Post edited by: sputnic81, at: 2006/03/23 19:04
- kawasakikid38
- kawasakikid38
- dan76kz900
Re: Finished Tank
23 Mar 2006 17:46
Wow ! those pictures are so bright I'm seeing spots ! Looks good !
- dan76kz900
Re: Finished Tank
23 Mar 2006 17:47
