High Temp Black chrome paint?
  • sakiguy
  • sakiguy's Avatar Topic Author
29 Nov 2009 10:46
#336490
My headers aren't looking too well. A lot of chips on it. The mufflers look ok though. Is there such a thing as black chrome paint? I've checked autozone and kragen, and haven't found anything. Tried a google search and am coming up with blanks. Bah, just would hate to have to shell out $300 and up to chrome these pipes right now. Looking for a short term solution. Thought about painting it black, but I don't think it will look good.
1983 KZ750 N2 Shaft
  • PLUMMEN
  • PLUMMEN's Avatar
Re: High Temp Black chrome paint?
29 Nov 2009 11:24
#336499
scuff it up and shoot it with black paint B) this was an old dumpster dive header i scuffed up the chrome on and painted
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
29 Nov 2009 12:11 - 29 Nov 2009 12:14
#336503
If you are attempting to recreate the so-called Kawasaki 'black chrome' finish, you may not be able to do it for large items, like mufflers or headers. It is possible to do it on small items as there are kits available from Caswell plating, etc that resemble this type of finish. The Japanese bike producers of the era all used that type of finish for their exhaust systems for a number of years and I have heard that the reason it is not currently available is that there are some environmental concerns regarding the plating process.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Last edit: 29 Nov 2009 12:14 by Mcdroid.
  • sakiguy
29 Nov 2009 13:02
#336516
Your bike looks great with the black pipes plummen..not too sure though how mine will look. I really like the black chrome look though.
So Mcdroid what do you mean by "so called"...are the kits a spray paint type finish...and kawasaki used similar kits like these?
That's too bad, I really like the black chrome look. Was even thinking about doing my handlebars black chrome.
1983 KZ750 N2 Shaft
  • JMKZHI
  • JMKZHI's Avatar
29 Nov 2009 13:32
#336520
The Spectre should look good w black pipes. Not sure about header paint, but engine paint comes in gloss, semi-gloss & flat black. As for rechroming, a chromer may not do your old pipes because their plating solution will get contaminated w rust, dirt & debris.
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
29 Nov 2009 13:34
#336522
The original black chrome finishes were not a spray-on finish but were an actual plating process similar to those currently being offered by Caswell Plating...but on a much larger scale...you might explore a black ceramic finish though...some KZR members have done that and although pricey, it looks good.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • txturbo
  • txturbo's Avatar
  • Ex-Kawasaki Mechanic 1981-1985
05 Dec 2009 06:10
#337587
Chromers replate rusty stuff all the time.They clean it first in a degreasing solution and then dip it in an acid to remove the rust.You may be able to use epoxy caliper paint if you can find it in black.There are several possibilities for the rear half, but the front half is going to be tougher since it gets a lot hotter.
1984 ZX750 E1 GPz Turbo
1984 ZX1100 A2 GPz
1984 ZX900
1996 KZ1000P Police bike
1970 Honda CT 70H 4sp manual
1965 Honda Dream 305
2003 Honda Shadow 1100
1971 Suzuki MT50 Trailhopper
1969 Camaro SS
1966 Impala
1966 Impala SS 427/4spd
  • TeK9iNe
  • TeK9iNe's Avatar
  • What did you do!?!
05 Dec 2009 06:22
#337588
You can have a sevice performed called jet-hot.
Its a super high temp powder coating process that coats the inside and out of the product and can withstand thousands of degrees heat and lasts very long in years.
They have some color options, including sterling that is really identical to silver. I've seen it myself, mirror finish!
They can even coat piston faces and skirts! :huh:
Cheers.
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
  • txturbo
  • txturbo's Avatar
05 Dec 2009 06:34
#337591
Thats expensive and I've heard of people having issues with durability of the coating when its not applied to new metal.
1984 ZX1100 A2 GPz
1984 ZX900
1969 Camaro SS
1966 Impala
  • TeK9iNe
  • TeK9iNe's Avatar
05 Dec 2009 06:58
#337592
Jet-Hot is the largest ceramic and high performance coating company in the world.
They do stuff for NASA... :huh:
If there were some coating isues, considering there rep, I would hope that they would warrant that!
It cost me about $12-foot for my exhaust. I paid just over $200.
Agreed, that could be expensive for some... chrome is just a little more too.
I just dont really like rattle can results on exhausts. It's never durable enough darnit!
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
