resin or bondo...
- roy-b-boy-b
Re: resin or bondo...
28 Nov 2009 16:20
Looks like we have been doing the same chore.
I had to make a tab for my side cover. I found a piece of plastic and three plied it to get the right thickness. I welded it together with a red hot piece of wire.
After i got it on the side cove with epoxy i rounded it off with a grinder so it would fit.
It was a little cool in the shop for this chore but warmed up nice this afternoon. Now my side covers match.
I used Bondo to repair the area around the broken tab. Roy
- 9am53
- homebrew, and some bbq
28 Nov 2009 16:26
yeah I used a piece of cork to sit in behind the tab to keep it in place. The ABS cement bonded quite nicely with the plastic of course, and it soaked into the wood due to corks porosity which in turn helped bond it to the plastic.
'84 GPz900r
'71 CB350
s289.photobucket.com/albums/ll231/9am53/
'71 CB350
29 Nov 2009 05:18
Fyi, KZ Information > Articles > Technical Tips.
Excellent plastic repair article by kzcsi.
Click here > Plastic Repair
Good Luck!
Good Luck!
- otakar
29 Nov 2009 05:26 - 29 Nov 2009 05:32
I use nothing but this.
www.evercoat.com/productDetail.aspx?pID=269
I have built up entire sections onto fairings and spoilers to tail sections. I have cut headlight openings out of fairings and built in new ons using nothing but this and cardboard.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 29 Nov 2009 05:32 by otakar.
- otakar
29 Nov 2009 05:34 - 29 Nov 2009 05:39
This fairing is half built out of FiberTech on to a plastic GPZ fairing. I wouldn't mess with anything els. I use it to re-bond broken side cover tabs, repair cracks and build complete new sections.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 29 Nov 2009 05:39 by otakar.
- otakar
29 Nov 2009 05:47 - 29 Nov 2009 06:01
This fairing which I am building for my Kz1300 and started out life as a 83 GPz1100 fairing is all FiberTech on top of plastic. some of it is as much as 1.5" thick in the top of the headlight opening, built up on a cardboard template. This two inch section was built up over a cardboard template and than the cardboard removed using water.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 29 Nov 2009 06:01 by otakar.
- otakar
29 Nov 2009 05:50 - 29 Nov 2009 05:58
This one extra step in the lower part of the fairing has been filled in with FiberTech the entire length of about 10"
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 29 Nov 2009 05:58 by otakar.
- otakar
29 Nov 2009 05:50 - 29 Nov 2009 05:53
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 29 Nov 2009 05:53 by otakar.
- otakar
29 Nov 2009 05:51 - 29 Nov 2009 05:55
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 29 Nov 2009 05:55 by otakar.
- 9am53
30 Nov 2009 05:03
wow, sweet! Where do you buy that stuff? If it's order only I don't know if they will ship to me in canada...
'84 GPz900r
'71 CB350
'71 CB350
- otakar
30 Nov 2009 06:07
I buy it at Carquest which is a Automotive paint and body supply chain store. I also buy all of my PPG pain there. I would call around to see which auto-body supply caries "Evercoat" materials. "Evercoat" is a competitor to "Bondo". I have not seen anything even close to this made by bondo. I just buy the small tube #100634 Tube. The stuff is not cheap but it is the best and goes a long way. With this stuff you get what you pay for. I also buy "Kevlar pulp" and "Chopped Graphite" as fillers. That way I can make fillers with the consistency of my choice. however the Fiber Tech is the best "out of the container" filler I have ever used. I have used it on every conceivable type of material imaginable, with the exception of Poly Ester Foam, with which it will not work.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
