Painting engine guards with rattle can properly?
- sakiguy
15 Nov 2009 16:16
I have stripped the black paint off the engine guards and sanded all the rust off. I bought some semi-gloss rustoleum paint. Should I primer first, then paint, then use a clear coat? Or should I just paint and then use a clear coat...or just paint without a clear coat.
1983 KZ750 N2 Shaft
- otakar
Re: Painting engine guards with rattle can properly
15 Nov 2009 16:50
First soak the parts in Muriatic acid. Wash them in distiled water and than paint with Rustoleum.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- MFolks
15 Nov 2009 19:33
If you want a hard finish, bake in the oven at 350 F for about an hour(stinks,so open windows and use a fan if possible).
- donthekawguy
15 Nov 2009 23:59
Have them powdercoated. Should only cost you about $15-$20.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
- dragnkaw1428
Re: Painting engine guards with rattle can properly?
16 Nov 2009 21:29
Or send em to me I'll paint em any color you want in the paint booth:)
Andy
- JMKZHI
17 Nov 2009 06:08
I would spray them w rattle can engine paint then bake 'em in the oven. The cost would be cheap & you'd have plenty of paint left over to do other parts.
- sakiguy
26 Nov 2009 14:54
JMKZHI wrote:
Man, I can't believe how good this works. I didn't use an oven, but I used an old toaster that was going to be thrown out any way. I'd just bake it in between a few coats and the finish seems very durable and very nice imo.
1983 KZ750 N2 Shaft
- JMKZHI
26 Nov 2009 19:50
Hmmm, you heated them between coats? Well, I hope that works. You'll know for sure after putting them to use. I simply paint parts as per the instructions, then bake them once - 20 minutes or so at 175, then raise the temp to 225 for another 20. I hang most parts on coat hangers to do it.
- 9am53
- homebrew, and some bbq
27 Nov 2009 07:04
If you bake parts, make sure that when they are hot (ie. when you take them out of the oven) you don't touch the paint, it will be really soft.
'84 GPz900r
'71 CB350
s289.photobucket.com/albums/ll231/9am53/
'71 CB350
