New fender on '78 KZ- what to put in the underside
- OLKZ
13 Nov 2009 04:23
I got my fender bent by some moron in a car. The rear fender on my KZ-650 (1978) got folded down to the tire. I was luck enough to find a new (old) one on e-bay, but the underside was understandably dirty and had a fair amount of surface rust. I cleaned off what surface rust I could with a brass brush though some remains.
Before I mount this back on the bike, what should I coat the street side of the fender with? Paste wax? Doesn't seem like that would last very long. Clear coat of some kind? It would have to come in a rattle can and I'm not sure what to use. Rust proofing undercoat? Rustoleum in a jet black?
The bike is original blue.
TIA,
Tom
TIA,
Tom
1978 KZ650B2 - Blue - runs!
New Dyna-S ignition & coils 6-2014
- JMKZHI
Re: New fender on '78 KZ- what to put in the underside
13 Nov 2009 04:42
My front fender has been treated w 3m rubberized undercoating - it's what I had at hand, so that's I used. I've used bar-b-que grill paint as a rust preventer on the underside of other parts.
- OLKZ
13 Nov 2009 07:24
Thanks! I appreciate the tip. Will the 3M stuff stick if I don't get the part totally clean of rust?
- JMKZHI
13 Nov 2009 07:35 - 13 Nov 2009 07:41
Probably. For sure you want the part clean & dry w all loose rust removed. Something else.... I completely forgot that I treated mine w DupliColor Rust Fix before applying the undercoating - it's one of those rust converter rattle-can sprays. And I refurbished a rear fender that wasn't too bad by cleaning it, etc, then spraying the underside w bar-b-que grill paint (as a rust treatment), followed by the same 3M undercoating.
Rust treatment & prevention - pic
Last edit: 13 Nov 2009 07:41 by JMKZHI.
13 Nov 2009 10:54 - 13 Nov 2009 10:56
Whatever you decide to use you really must remove all the rust first. Here's something I've used with great success. Soak the underside of the fender good and keep it wet with this stuff for a couple hours and the rust will be gone. It may take a couple treatments. Then wash & dry it and paint. This stuff is made for firearms. It doesn't seem to affect the good metal.
Click on "gun blueing" then "metal finishing" then see Birchwood Casey Blue & Rust Remover Product 16125 -BR1
www.birchwoodcasey.com/sport/index.html
Last edit: 13 Nov 2009 10:56 by 650ed.
