What guage of metal / type of metal should I use?
- YUKABODOS
10 Nov 2009 08:45
I am considering fabricating my own seat pan and was looking for input on what guage and type of metal I should use?
Aluminum?
Aluminum?
- brian512g
Re: What guage of metal / type of metal should I use?
10 Nov 2009 10:55
Fiberglass or carbon fiber is easier for me to work with...
10 Nov 2009 13:48
i wouldnt go any thinner than .065 and .125 is too thick.whatever steel hot/cold rolled shouldnt much matter,long as the price is right
leon holmes
leon holmes
- Nebr_Rex
10 Nov 2009 15:44
12 or 14 guage,which would roughly be how many pieces it would take to equal an inch.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- PLUMMEN
10 Nov 2009 16:27
aluminum is a lot more foregiving if you aneal it first with a torch
- Becker
- The Doctor Will Rise Again
12 Nov 2009 18:45
Just got done doing mine out of 12 gauge. I used a tin snips and a set of sheet metal hammers to pull it off. I didn't use heat and it turned out ok. I'll post pictures after this weekend.
78 KZ750B3
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
81 CB750K Super Sport
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
- loudhvx
12 Nov 2009 19:38
I used .100", or was it .095" aluminum.
To make the edge bends nice and neat, I first ground a shallow groove on the backside with a thin grinding wheel along a metal straight edge. Then the bend went beautifully.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- PLUMMEN
12 Nov 2009 20:07
Becker wrote:
if you banged a seat pan out of 12ga sheetmetal using tin snips and a hammer youre a better man than i am! :laugh:Just got done doing mine out of 12 gauge. I used a tin snips and a set of sheet metal hammers to pull it off. I didn't use heat and it turned out ok. I'll post pictures after this weekend.
