2 ways to clean rust from gas tank
  • newOld_kz1000
  • newOld_kz1000's Avatar Topic Author
  • FlimFlamFlibbityFlee !! BoonFryedShickaMuhZee !!
23 Oct 2009 08:36 - 23 Oct 2009 08:38
#329129
I'm cleaning my rusted tank insides and found 2 chemicals:
1) Phosphoric acid -- it's the stuff that the Kreem product uses to clean the tank. It's supposed to be the 'right' way to go because: "This type of acid does not attack and errode the metal, but instead converts the rust back into metal, and then leaves the surface coated with a phosphate ion so it will not corrode again."
2) Hydrogen Chloride -- this is toilet bowl cleaner -- a buddy of mine showed me a before/after of his gas tank. It was definitely rusty before. IT WAS BRAND-NEW LOOKING AFTER! He poured in straight toilet bowl cleaner whose main ingredient is Hydrogen Chloride (the product is called "The Works Disinfectant Toilet Bowl Cleaner).
He positioned the gas tank on one side for 10 mins., then repositioned the tank on the other side for 10 mins., and so on until the cleaner had touched all 4 sides of the inside of his gas tank -- the cleaner sat on the 2 side surfaces of its insides, and then sat on the inside top and bottom for about 10 minutes each, then he flushed the gas tank out with water, and flushed it with gasoline, then filled it with gasoline, SPOTLESS.
WHICH IS THE BEST MOST EFFECTIVE PRODUCT? My tank is MEGA-RUSTY !!!!!! on the inside.
Thing is, I *know* the Hydrogen chloride solution works! I saw my buddy's gas tank insides before the toilet bowl cleaner treatment, and then after -- wow what an improvement!
But I've never seen, firsthand, this 'phosphoric acid' work.
Thanks.
1978 kz1000 A2 with Kerker
1980 Z1 Classic with Kerker
Last edit: 23 Oct 2009 08:38 by newOld_kz1000.
  • Locozuna
  • Locozuna's Avatar
Re: 2 ways to clean rust from gas tank
23 Oct 2009 09:57 - 23 Oct 2009 09:59
#329137
I have used the Kreem and it works well but if you have bad scale rust you better get a package of BB's and roll that tank around in the dryer for a half hour or so before treatment. Plug up the holes in the tank pour in the BB's and then stuff it in the dryer with blankets, towels, bubble pack. Run the dryer with no heat. Turn the tank the opposite way and run it again. Now do the treatment to get into the corners. If you run out of treatment you can re-do with white vinegar. Not as strong but effective.
GLuck!
Depending how bad the tank is, be ready. This might open pin holes but better to find out with these than a tankful of gas.
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
"If you seek for Eldorado!"
Last edit: 23 Oct 2009 09:59 by Locozuna.
  • txturbo
  • txturbo's Avatar
  • Ex-Kawasaki Mechanic 1981-1985
25 Oct 2009 15:31
#329572
A short piece of small chain works better than BBs. Easier to remove.The best kind is the kind used for swing sets.
1984 ZX750 E1 GPz Turbo
1984 ZX1100 A2 GPz
1984 ZX900
1996 KZ1000P Police bike
1970 Honda CT 70H 4sp manual
1965 Honda Dream 305
2003 Honda Shadow 1100
1971 Suzuki MT50 Trailhopper
1969 Camaro SS
1966 Impala
1966 Impala SS 427/4spd
  • pjed
  • pjed's Avatar
25 Oct 2009 16:34
#329585
I used this stuff called Evaporust on a CB tank that was really rusty and it worked great. Ended up using 2 gallons and had to fill it and leave it overnight soaking for each side. I believe it was around $22/gallon from O'Reilly Auto. The nice thing is that you can reuse it which I did with various bolts, etc...
1976 KZ400 D3
2008 Kawasaki Ninja 250 (sold)
2005 Kawasaki ZX6RR (sold)
2013 Harley Davidson 883 Iron
  • newOld_kz1000
25 Oct 2009 23:11
#329667
I'll try it! Thanks.
Thanks for the chain tip also!
How much total time do I shake the tank with the chain inside? Is 1 hour enough (with breaks to rest my arms)?
Also: do I put the chain in with the Evaporust, or do the chain treatment first?
  • pjed
  • pjed's Avatar
26 Oct 2009 08:47
#329717
I'll get the customer support number for Evaporust when I get home and post it. When I called them they were very helpful.
1976 KZ400 D3
  • sbulla
  • sbulla's Avatar
  • 1980 KZ1000 LTD
26 Oct 2009 13:33
#329753
Do any of these chemicals attack paint? Should care be taken to keep them off?
Sonny
Now----
1980 KZ1000 LTD (Kerker 4-1, K&N pods, Dyna gray coils)
Gone but not forgotten----
1966 Honda 305 Superhawk
1969 HD 350 Sprint
1971 500 H1
1972 250 F8
1972 750 H2
1973 KX250
1995 HD Sportster 1200
2000 HD Softail
2002 KLR650
  • pjed
  • pjed's Avatar
26 Oct 2009 13:53
#329754
Evaporust customer support number is 1-888-329-9877
1976 KZ400 D3
  • racer54
  • racer54's Avatar
26 Oct 2009 15:35
#329764
  • KZQ
  • KZQ's Avatar
  • Administrator
  • Administrator
26 Oct 2009 19:05 - 26 Oct 2009 19:08
#329849
I suppose the articles are a bit removed. In any case take a look at this:
kzrider.com/index.php?option=com_content...view&id=22&Itemid=11
KZCSI
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Last edit: 26 Oct 2009 19:08 by KZQ.
  • newOld_kz1000
27 Oct 2009 19:07
#330000
KZCSI
Wow man. Thanks. That will come in handy bigtime!
The only step I've taken so far is to find a source for the gallon-size jug of Evapo-Rust ($19.99 at Harbor Freight Tools).
A buddy of mine gave me a huge bag of 'tumbling media', which is basically rocks of some composition with sharp edges all around. I decided to toss those into my empty gas tank and shake it around to free up the loosest bits of rust.
I have gotten lots of good tips here -- I found a plumbing stopper at OSH that neatly seals my gas cap hole when I screw in the stopper's butterfly nut to expand its rubber gasket into the gas tank hole.
So I'm a-shakin and a-shakin my tank with the tumbling media inside, like a crazy damn monkey in a zoo cage and a mental problem from being stuck in a cage too long. Shakin-and-a-shakin. When I look inside, out comes a bunch of rust dust, which is cool -- I'm gettin' somewheres. I like that sense of progress, shake some more.
And now with Mr. KZCSI's help I have an excellent path forward, and thanks to all -- I feel pretty good just now about getting this rusty tank innards cleaned up!
I'll post the progress, thanks!
  • mtkawboy
  • mtkawboy's Avatar
28 Oct 2009 14:55
#330144
Easier to get something magnetic out of the tank then rocks
