solo seat
  • sbjones
  • sbjones's Avatar Topic Author
solo seat
19 Mar 2006 21:25
#32715
started buildingmy solo seat set up tonight. i think it is turning out really well. it will shorten my seat by about 12-14 inches. this is want i wanted!!!! i will try and put up some pics in here of it.
  • dutchz
  • dutchz's Avatar
Re: solo seat
19 Mar 2006 22:33
#32730
sounds good, let's see em!
1974 Kawasaki Z1
Stock front hub and rear axle.
  • sbjones
Re: solo seat
20 Mar 2006 00:09
#32740
ok here goes a try at some pics.
  • sbjones
Re: solo seat
20 Mar 2006 00:11
#32741
this part of it is going to be fiberglassed in and supported with steel strips. the front flat spot is about 2 " above my cut down seat, so this will be a little cushion. i will post more pics whn i get it done.
thanks
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
Re: solo seat
20 Mar 2006 17:39
#32926
Keep us updated. I need ideas for a single seat! ;)
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
  • dutchz
  • dutchz's Avatar
Re: solo seat
20 Mar 2006 17:44
#32928
Looks good! What kind of foam are you using there?
1974 Kawasaki Z1
  • Shoe48
  • Shoe48's Avatar
  • Live each day as it is your last
Re: solo seat
20 Mar 2006 18:04
#32934
What wheel and swing arm is in the picture ? The seat looks good keep posting pictures ,, I like your idea so far
  • sbjones
Re: solo seat
21 Mar 2006 00:31
#32998
well, the foam that i used is the foam that hobby people use to put plastic flowers in (ya know like at a restaraunt) it worked out great. easy to shape and very light. glues together easily to make more.
alss i am going to do is frame it. then fiberglass over it. it has a ridge about 2" high in the back of the seat. so i will put a little pad there.
as far as the swing arm and tire, they are off of a 2003 gsxr. the front is going to be the same. (a matching set)
i will keep you guys up dated with pics on the seat stuff.
