How to repair bolt hole in the tail lite?
- JMKZHI
27 Sep 2009 20:10
A tail lite bolt head snapped off & I tried to redrill & tap the hole but buggered the job. I can thread the bolt into the hole, but it's a loose fit. Is there a good fix for this? Such as to refill the hole, drill & tap it. Or some product that does virtually the same thing. I don't want to load the threads w teflon tape or anything like that. Unless I have too.
- Kawickrice
Re: How to repair bolt hole in the tail lite?
27 Sep 2009 20:20
I have seen JB Weld do wonders. Fill the hole and chase the threads before it fully hardens. If you can get enough in there without removing it when you chase it it might work for ya.
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
- kzrider4life
27 Sep 2009 20:52
Drill through and put a little nut in the back. I had a kz with this done and i didnt notice till my tail light bulb went out.
Current bike..1977 kz1000 1075cc kit,dyna everything,lotsa chrome,kerker pipe.
- Bluemeanie
28 Sep 2009 06:05
Is there enough meat to drill and tap to the next larger size?
- JMKZHI
29 Sep 2009 08:18 - 29 Sep 2009 08:20
I'd rather not drill the hole out any bigger.
Here's a product. It's not exactly what I was thinking of, since the problem is that the hole is too big.
Last edit: 29 Sep 2009 08:20 by JMKZHI.
- riverroad
- 1980 1000LTD B4
29 Sep 2009 12:43
Put a thin coating of car wax on the threads of the screw, let dry, gently brush threads with an acid brush, fill the hole with JB-Weld, install waxed screw and let it cure completely. Gently but firmly back the screw out. As a matter of fact, use an allen screw or hex head screw the same size as the factory screw, cause it's gonna be tight, but it works.
29 Sep 2009 18:51
kzrider4life wrote:
Could get a longer screw, same diameter, with appropriate size/style head, and acorn nut, from hardware store. If necessary, shorten new screw to exact length needed to tighten into the acorn nut.
The acorn nut won't be noticed, and will afford a smooth surface that doesn't snag a cleaning rag or cut a finger when wiping the area.
Good Luck!
Good Luck!
