Tank Rust removal
  • Dave Sloan
  • Dave Sloan's Avatar Topic Author
Tank Rust removal
18 Mar 2006 14:50
#32261
Hey guts,
I read exlent post a while back on removing rust in a tank using a 10 amp battery charger, I ma keen to give this method a go but my battery charger is only 4 amp Will this still work?
Thanks
Cheers
DAve
Z650B2 - Injected
  • Kawozaki
  • Kawozaki's Avatar
Re: Tank Rust removal
18 Mar 2006 17:44
#32342
Yes...I'd use some baking soda in there as well---worked nicely on my tank. I think that phosphoric acid works just as well, but it depends on how "Tree Friendly" you are;)
  • agawam
  • agawam's Avatar
19 Mar 2006 12:34
#32550
  • Dave Sloan
19 Mar 2006 23:31
#32735
Thanks for the replies guys, Ill give it a go.
Cheers
Z650B2 - Injected
  • 900cows
  • 900cows's Avatar
20 Mar 2006 05:44
#32758
Then,just buy some tank sealer,Dump in,move tank around to coat entire inside surface,let dry.Now u will not have to worry about it ever rusting agin.
  • KZQ
  • KZQ's Avatar
  • Online
  • Administrator
  • Administrator
20 Mar 2006 06:07
#32760
Hey Guys,
I tried the electrical method without much success, but then I tried salt instead of baking soda. I've got another tank I could try it on. In any case the electrical method doesn't really get to the top of the tank very well. I guess it depends on where the rust is.
As for either method being more or less tree friendly. None of these methods generate any waste that isn't neutralized by just dumping the excess on an old slab of concrete. Except, of course, the electrical method which requires some coal fired generating plant to spin up another few kilowatts worth of acid rain.
Lastly, sealing a tank that doesn't leak is a real waste of tank sealer, your time and the value of your bike.
Check out my article in the articles section on rusty tanks.
KZCSI
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
  • btchalice
  • btchalice's Avatar
20 Mar 2006 06:51
#32764
you might have to put the electrode in the tank somehow without touching the tank
Terry Meyer / Wichita KS
76 kz900 w/1000 motor TWZTD
  • JMKZHI
  • JMKZHI's Avatar
Re: .
20 Mar 2006 07:07 - 03 Dec 2008 19:50
#32769
del
Last edit: 03 Dec 2008 19:50 by JMKZHI.
  • OKC_Kent
  • OKC_Kent's Avatar
20 Mar 2006 08:10
#32792
You can find washing soda in some grocery stores, in the laundry area. Not all stores carry it.
Cashion, OK
78 KZ650 B2 85,000+ miles
  • N0NB
  • N0NB's Avatar
  • Blue handles better
20 Mar 2006 08:39
#32799
I'm quite happy with the results I obtained with the POR-15 tank sealer kit. This tank had rust flaking off the top side of the tank and was fouling the carbs and plugging the inline filer. The kit allowed me to preserve the original paint on the tank and was all done at room temperature.
I have one or two more tanks I plan to do the same thing with. The process is worth it to me.
- Nate >>
Nate
1979 KZ650 (Complete!)
1979 KZ650 SR (Sold!)
1979 KL250 (For sale)
1994 Bayou 400 (four wheel peel :D )
  • TheTrout
  • TheTrout's Avatar
20 Mar 2006 09:26
#32805
I've always used the Kreem tank sealer. One change though, I use the acid etch full strengh and just keep swishing it around. Gets it done quicker and with a better etch. My KZ has had it in the tank for 12 years now!
1978 KZ1000B2
  • KZQ
  • KZQ's Avatar
  • Online
  • Administrator
  • Administrator
20 Mar 2006 19:02
#32951
Hey Nate,
The last thing I want is an argument. I certainly have none with you, BUT.
The best thing a manufacturer of anything can do is to convince the consuming public that their product is required universally.
Dupont has conned most of the world into thinking that every body who's building a home needs TYVEK. What a CROCK! The stuff is a passable air barrier and that's it. It sucks as a water barrier and they know it!
Whomever puts out Kreem and Pour15 wishes that they could someday be as sucessfull as Dupont at foisting their good product up the flag pole far enough that it can be somewhere near TYVEK.
If you tried the technique that I suggest for cleaning your tank the rust and scale would be history, you would have spent about $6.00 and your tank would be as good as a new tank. The process I have described has never damaged any paint on any of my tanks, twelve and counting.
As a collector of bikes I can tell you that a rusty tank is worth more than a sealed tank any day.
KZCSI
Post edited by: KZCSI, at: 2006/03/20 22:04
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
