seat rubbing tank
- CTSZ1
seat rubbing tank
18 Mar 2006 13:29
I have recently had this bike painted and have noticed that my seat rubs the back of the tank when I ride. Do the seats on a Z1 normally rub the tank or is my seat pan warped? Any suggestions as how to keep the paint from getting marred.
Thanks
Thanks
- wireman
- Visitor
Re: seat rubbing tank
18 Mar 2006 16:14
yeah that is a common occurence,maybe try slipping a small strip of rubber in there.goodluck,happy wrenching!
- The Milkman
18 Mar 2006 18:10
I'm not sure how your Z1 tank mounts. But on my 650 there is a rubber grommet that a tab on the back of the tank slides into. Mine was loose and the seat would rub. I got an oring that fit into the groove on the grommet and forced in back into the frame. Problem solved.
Les
Les
- patmann
20 Mar 2006 08:02
ALL Z1 tanks that I have seen, do rub. It's just the nature of the beast.
I saw a guy put a layer of tape in the place his rubbed, to protect his paint. His tape job looked like crap. It stuck up OVER the top of the seat. . If you did a careful job, I'm sure yours would look better.
For me, I just wax the heck out of it, and figure it's part of the doing business with the old gal.
Pat
Post edited by: patmann, at: 2006/03/20 11:03
Pat
1974 900 Z1 modified to look like a LTD , some engine mods. But I still have all the original parts.
1977 1000 project bike
1972 H1 project bike
If pro is opposite of con, then what is the opposite of progress?
- mgweiss
20 Mar 2006 12:34
You may be able to loosen the bolts that hold the seat hinges to the seat pan, then move the seat back a little. If I remember right there's some play in the bolt holes, or you could ream out the holes to create some play.
- mgweiss
20 Mar 2006 12:35
- BARNEYHYPHEN
20 Mar 2006 13:22
Mine obviously does the same and I was thinking you might be able to put a neat piece of that clear thin flexible plastic sheeting stuff that you use on the front of car bonnetts (hoods) to protect them from stone chips?
Haven't done it yet but will do when I fit my newly painted tank.
- patmann
21 Mar 2006 13:37
I'll bet that would work;)
Let me know how it turns out, as I might do it too.
But YOU first !!
But YOU first !!
- ltdrider
21 Mar 2006 14:24
I noticed my seat was rubbing on my tank about a week after my paint job. Not good!
I use a blue shop towel (high quality paper towel), folded to fit between the seat and the tank. Works great and stays put, but you have to remember it's there when you lift the seat.
'76 KZ900 LTD (Blaze)
'96 Voyager XII (Dark Star)
Greensboro, NC
Greensboro, NC
