remove gasoline stain on paint?
  • Philk7
  • Philk7's Avatar Topic Author
  • KZ750 '81 LTD
09 Aug 2009 12:13
#312691
Hi
Do you have a hint to remove gaz stain on the paint?
You are my hero if you know that!
Thank!
KZ750 '81 LTD
  • JMKZHI
  • JMKZHI's Avatar
Re: remove gasoline stain on paint?
09 Aug 2009 15:29
#312706
Paint info needed... most likely.
  • Philk7
  • KZ750 '81 LTD
09 Aug 2009 16:55
#312724
it's dark gray paint ( the gray of VW rabbit 09 )
It's a big stain of gasoline...
KZ750 '81 LTD
  • AtLarge
  • AtLarge's Avatar
09 Aug 2009 18:37
#312797
I had stains from the filler hole on my tank running down both sides from the PO overfilling and not wiping it off. I got a hot tip from a member of another board. Use baking soda and water. My tank is black OE and it took it off completely. I did cheat a little by using a foam disk on my battery powered drill and just kept going back and forth over the stains but you can get just as good results with a rag dampened and dipped in the soda. Don't reuse the soda when your done. :P
1973 Honda CL70-K3
1975 Kawasaki 350 F9-C
1983 Kawasaki KZ750-K1
1994 BMW K1100RS
2008 Suzuki GSX1300-BKK8 #1120
  • Philk7
  • KZ750 '81 LTD
09 Aug 2009 19:58
#312811
really? I give you some news.
Thank!
KZ750 '81 LTD
  • Philk7
  • KZ750 '81 LTD
10 Aug 2009 17:05 - 10 Aug 2009 17:06
#312995
You use polishing disk like this?
It doesn't work with rag.
KZ750 '81 LTD
Last edit: 10 Aug 2009 17:06 by Philk7.
  • AtLarge
  • AtLarge's Avatar
10 Aug 2009 18:18
#313009
No, actually I used a disk and foam pad leftover from a Harbor Frieght kit I used to polish the lenses on my cars. Shouldn't matter though just make up a paste with water and go to town. After that I followed up with rubbing compound. This is my tank now. Are you sure it's gas stains?
1973 Honda CL70-K3
1994 BMW K1100RS
  • Philk7
  • KZ750 '81 LTD
10 Aug 2009 19:26
#313030
i sure it gas stain, it's start from the filler holes.
I'll try another time with more soda!
KZ750 '81 LTD
  • bowtie39
  • bowtie39's Avatar
10 Sep 2009 14:19
#320488
Had any luck removing the stains?
Thanks
