Ceramic Coating...Should I?
- Koda1
18 Jun 2009 07:50 - 18 Jun 2009 09:07
I was thinking of having my header pipes coated in ceramic. The pipes are discolored(bluing and brown). I tried all the latest removers, but the pipes still look awful.
I heard about ceramic coatings and wondered if I should have it done. Does anyone have any knowledge on this?
'78 CB750K
'82 650 Nighthawk
'82 KZ750
"The problem with socialism is that you eventially run out of other peoples money"
M. Thatcher
'82 650 Nighthawk
'82 KZ750
M. Thatcher
Last edit: 18 Jun 2009 09:07 by Koda1.
- Mortarmanmike
Re: Ceramic Coating...Should I?
18 Jun 2009 08:10
I've had my buell pipes Jethot coated. Looks really good. It doesn't look anything at all like chrome. Up close it looks like silver paint. From any distance at all it kinda looks like brushed stainless. Maintenance free. I've had it for 3 seasons and looks just like it did out of the box. Not cheap though.
1979 KZ1000 Shafty
- Koda1
18 Jun 2009 08:17
Thanks...anything has got to look better than the blue/brown discoloration it has now.
'78 CB750K
'82 650 Nighthawk
'82 KZ750
M. Thatcher
'82 650 Nighthawk
'82 KZ750
M. Thatcher
- rstnick
18 Jun 2009 13:47
I had my rusty Kerker high heat powder coated black.
First sand blasted then coated.
Been holding up well for the last two years.
Sure beats the high heat BBQ paint, but did cost a lot more.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
- timebomb33
18 Jun 2009 16:11
well worth doing a freind of mine just did his vance and hines pro pipe that he has used hard every summer for about 12 years and the pipe lookslike new again not chrome but like mortorman said brushed stainless and not only that but it actually made more power to because the pipe holds the heat in the pipe and helps scavange the exhaust from the other cylinders.
I THINK MY POWERBAND BROKE
- MFolks
18 Jun 2009 17:15
I had a Kerker 4 into 1 done many years ago by a company called Flame Spray. They grit blasted the paint off and then Aluminum sprayed it. It's been holding up well for all these years.
- Tyler
23 Jun 2009 08:40
I had a chrome Kerker header in tough shape. I bead blasted it to get the rust off and rough up the chrome surface. Then I used a cermaic header paint from NAPA called VHT. It was reccommended by another member on this forum. The VHT worked great, and best of all its cheap.
"74 Yamaha DT 400 Enduro
