Rattle can painting (flat or matte black)
  • supa phatty J
  • supa phatty J's Avatar Topic Author
09 Mar 2006 11:13
#29622
I know this has been covered before and I have used the search (and yes I will go back and RE-read threads, too).
I decided to post here, even though I no longer have the KZ, because it seems rattle can painting is common with a group of people that own older bikes. :)
Anyway, I want to paint my 2000 SV650. It has rash on the tail from a lowside, so I want to repaint over it. (It will hurt some to lose that badge of honor though...)
I want the plastics to be a flat or matte black. First off, what is the difference between flat and matte paints? What would you suggest I spray for this? Should I just go with a black primer (suggestions on brand)?
I never painted anything, nor have I ever used spray paints, so please be easy... ;)
The tank would be the last thing I want to do (if I do it), and it will be an orange or yellow...I think. If you'd like to input an early suggestion on that, feel free. :)
Thanks!!!
Edit: ohhh looks like all the board settings have been reset since I was last here...
Post edited by: supa phatty J, at: 2006/03/09 14:14
  • dutchz
  • dutchz's Avatar
Re: Rattle can painting (flat or matte black)
11 Mar 2006 00:05
#30041
Flat black is tricky... You'll see fingerprints and the likes anytime anything or anyone (including you, gas, motoroil and W40) touches the bike. I really like the Rustoleom ToughGuard Semi Flat which gives you a low, hot-rod like sheen and looks WAY better than all flat black. I used their grey primer, which is fine.
1974 Kawasaki Z1
Stock front hub and rear axle.
  • dutchz
  • dutchz's Avatar
11 Mar 2006 22:58
#30252
Sorry, that would be KRYLON ToughGuard semi flat, not rustoleum.
1974 Kawasaki Z1
  • MattBlack
  • MattBlack's Avatar
13 Mar 2006 13:41
#30719
Yeah I agree, a lot of people say "flat black" but it's rare that flat black is really what you use. Unless you're realy keepign it on the cheap. ;)
Matte Black and Satin black is what you want to use. It bacially low-luster, but still has a slight sheen to it and resists scuffs and prints etc, as was mentioned.
You can always use a flat black though if you are goign to coat it after with a matte clear. The clear will help protect it againt crap as well.
  • Mark Wing
  • Mark Wing's Avatar
13 Mar 2006 14:42
#30738
Flat will be a headache. Matte or semi= gloss black will be more forgiving.
Mark
Yorba Linda Cal.
  • btchalice
  • btchalice's Avatar
13 Mar 2006 15:07
#30748
i used duplicolor high temp engine paint with ceramic if the pic posts this is what it looks like
Post edited by: btchalice, at: 2006/03/13 18:11
Terry Meyer / Wichita KS
76 kz900 w/1000 motor TWZTD
  • supa phatty J
14 Mar 2006 20:44
#31218
If I use a black primer, can I go straight to a matte clear on top of that? Or should I put some satin/matte paint on top of the primer first?
Dutchz, did you put any clear over your semi-flat paint?
btchalice, that paint looks like it could be a good candidate for when I do my exhaust. The exhaust is aluminum. Would I need to sand it down before, or just clean and spray?
  • btchalice
15 Mar 2006 04:45
#31288
on aluminum i would sand it smooth and kill any shiny spots to make sure it sticks
  • cratgo
  • cratgo's Avatar
15 Mar 2006 05:36
#31292
don't know if anybody else has had this problem, but, i had to buy some duplicolor adhesion promoter for the plastics because the paint just wanted to bead up in some spots even after sanding and scuffing, the stuff worked though
  • ran429
  • ran429's Avatar
  • Master of FREE rides!
15 Mar 2006 10:46
#31357
On aluminum, always spend the money for ACID etching primer. Paint wont just Stick magically to aluminum for some reason.:whistle:
