what to powdercoat
  • zmaniscalco
  • zmaniscalco's Avatar Topic Author
what to powdercoat
28 May 2009 19:10
#294739
I am ready to send my frame off to get powdercoated, and would like to know what else I should send. any ideas
78 kZ1000
79 KZ1000 Ltd turbo
  • PLUMMEN
  • PLUMMEN's Avatar
Re: what to powdercoat
28 May 2009 19:12
#294741
anything you want,i dont like to powdercoat frames its too hard to fix screwups on something that big B)
  • MFolks
  • MFolks's Avatar
28 May 2009 19:16
#294743
When you get it back, be sure to remove the powder coating where the ground wires will go.
  • gane
  • gane's Avatar
28 May 2009 19:21
#294748
If there was anything i wanted to powdercoat it would be lower fork legs. G
[img][/img] 1977 KZ1000A1
28 May 2009 20:08
#294759
gane wrote: "If there was anything i wanted to powdercoat it would be lower fork legs. G "
In fact, you may want to look into some of the metallic powder coat colors for the legs. They can make them look like aluminum or chrome. Ed
  • KZ250LTD
  • KZ250LTD's Avatar
28 May 2009 20:33
#294763
You can send more or less all your bits and bobs. Just make sure they know where not to powdercoat. Many people have had to spend a whole lot of time working to get even a few stray particles out of their bearing races on the neck, etc
79 KZ1000ST
Past:
Many.
  • KawiConvert
  • KawiConvert's Avatar
29 May 2009 00:27
#294779
Anything thats not plastic! :laugh:
1978 KZ650 D1 ~ Carb jetting: 107.5 & 20 & 4th groove with pods and 4-1 Exhaust
  • StreetfighterKz
  • StreetfighterKz's Avatar
29 May 2009 04:20
#294794
If you're having the frame powdercoated, then I'd get the swingarm, triple clamps, footpeg mounts, motor mount plates, battery box, etc. done at the same time.
later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
  • zmaniscalco
29 May 2009 17:41 - 29 May 2009 17:42
#294905
ok, and thanks for the input.
how about headlight and gauge housing, and all thoese little pieces that were painted black at one time?
any pros or cons?
78 kZ1000
79 KZ1000 Ltd turbo
Last edit: 29 May 2009 17:42 by zmaniscalco.
  • kzr750r1
  • kzr750r1's Avatar
29 May 2009 19:29 - 29 May 2009 19:30
#294925
One con that is about cleared for me is the bar riser on the 82 Gpz. It turned into a bear to compress the powder over they years to keep the bars from moving later...
I's all over now after being taken on and off so many times. It's compressed to the point there is no more give in the surface.
It's one of the things the nascar teams had to learn about with wheel lugs. They weren't staying on after a few laps and needed to scrub out the contact point so there was a good bite lug to rim.
In all Powder is great but remember the only way to patch is spray over with other paint that matches closly....
My 82 was stripped back in the early 80s and all the bits I could powder were. All satin black.
Later after the second rebuild creating the KZR other bits were powder gloss black...
Now it has about 5 or 6 different black finishes on the bike.
If you want to avoid powder on mated surfaced there is a tape used to mask that can handle the heat cure process...
I was luckey on the second pass in the 90s to have a powder shop next door. The owner just gave me the tape to mask all the parts myself. Still made a couple mistakes.
Live and learn...
KZ750R1 + 1991 ZR750 = KZR750R1
Better to be shot out of a cannon then squeezed through a tube. - HST
Last edit: 29 May 2009 19:30 by kzr750r1.
  • KawiConvert
30 May 2009 09:26
#295039
Actually regular masking tape can handle the heat, just not very well. And you'll need to remove the adhesive residue with WD-40 and some time. I found this when I didn't have enough of the hi-temp masking tape left and needed to seal off the back of the valve cover.
I'd send anything that is currently painted to be PC'ed. It is a tougher finish than paint and one less thing to worry about. I had my battery box, engine mount brackets, wheels, frame, swingarm, brake stay, front fender, etc pc'ed. I'm going to coat the calipers someday when I have time to take them apart and rebuild them. Also, ask for a coating that will hold up well against brake fluid, gas, oil, etc.
  • kzr750r1
  • kzr750r1's Avatar
31 May 2009 22:56
#295434
Also whomever your doing it with should show you some finished product to ensure you approve of their work.
Mask off mount points and mating surfaces and you'll be very happy. Good point on the ground lugs!
Just keep in mind if you absolutely have to there are spray paints that can match well for touch up. Just try and keep that to a minimum. ;)
One of these days I'll tear mine down for a new finish.
Just not yet. I ain't done yet. :P
