Front Trapezoid Master Cylinder
  • athlonwirez
  • athlonwirez's Avatar Topic Author
19 May 2009 09:10 - 19 May 2009 09:15
#292629
I'm going to be rebuilding the front master cylinder, and it is in need of new paint. Once I strip all the old paint, or what is left of it, what would be a good route to go. Should I use a type of spray paint, have it powder coated...? Also, what type of finish should the paint be? Flat, semi-gloss, etc..., I think semi-gloss. I'm hoping this will have it working and looking like new. I would rather not give a lung for the cost of a rebuilt unit from Redline.
1978 LTD Partial Restoration in Process. (Do not have orginal exhaust)
Last edit: 19 May 2009 09:15 by athlonwirez.
  • Skyman
  • Skyman's Avatar
Re: Front Trapezoid Master Cylinder
19 May 2009 09:15
#292634
The trouble with painting a master cylinder is that if brake fluid ever leaks, or spills, it quickly eats into the paint, and causes it to bubble up and flake off. So if powder coat is more resistant to brake fluid, and can be applied without damaging the M/C, then that may be the best way to go. As for which finish, personally, I would go with a semi-gloss or satin finish.
West Linn, OR
  • athlonwirez
19 May 2009 10:05
#292653
I'm not a paint expert. Maybe a satin powdercoat would do well.
  • RonKZ650
  • RonKZ650's Avatar
19 May 2009 11:05
#292675
If you do the dot5 routt you don't need to worry about paint. Do your semigloss and it will be fine.
  • athlonwirez
19 May 2009 11:55
#292683
Thanks Ron, if you have been going that long trouble free it sounds good to me.
  • riverroad
  • riverroad's Avatar
  • 1980 1000LTD B4
21 May 2009 07:06
#293052
Another option is to just remove the paint and polish the aluminum. Looks great, but you've just added another love chore to your machine.
