Tank Repair
  • GalwayZ
  • GalwayZ's Avatar Topic Author
Tank Repair
03 May 2009 11:51
#287488
anyone ever heard of a successfull way to repair a pinhole in a fuel tank by brazing - obviously by successfull i mean surviveable!!
  • kano
  • kano's Avatar
  • Not Another Bloody Limey!
Re: Tank Repair
03 May 2009 11:53
#287489
ive had pinholes brazed up worked fine B)
  • GalwayZ
Re: Tank Repair
03 May 2009 11:57
#287491
anything done before hand like purging the tank or filling with water ?
  • Mark Wing
  • Mark Wing's Avatar
Re: Tank Repair
03 May 2009 13:31
#287519
I prefer to mig-weld them. I run about 5 psi through the tank while welding.
Mark
Yorba Linda Cal.
  • kano
  • kano's Avatar
Re: Tank Repair
03 May 2009 13:43
#287520
we flushed it out first.
brazed it up.
filled with water checked for leaks.
drained and re brazed a weeping whole.
re filled with water let sit re checked it for leaks,
all ok drain out water flush out with some diesel,
to stop flash rusting.
fill with old gas drain, fill with good gas.
go for a ride.
that's what i did hope it helps.
  • GalwayZ
Re: Tank Repair
03 May 2009 14:04
#287524
Thanks for the tips - Im hoping this can be repaired - its not a rust hole - my own mistake, changed the coils replaced the original philips head bolts with allen heads - damn thing rubbed on the underside and wore a tiny hole - you live and learn
  • Grantl
  • Grantl's Avatar
  • KZRider is Da Bomb!!!
Re: Tank Repair
03 May 2009 16:26
#287562
I repaired a rub through hole with epoxy tank and radiator repair kit. About 5 dollars from Autozone. Still working great.
1981 KZ1000 CSR
1983 KZ750 Project Bike
1990 550 Zephyr
1994 KZ1000 P
  • PLUMMEN
  • PLUMMEN's Avatar
Re: Tank Repair
03 May 2009 16:32
#287564
Mark
im with mark on a punched hole.for heavily pitted areas i like lead B)
  • N0NB
  • N0NB's Avatar
  • Blue handles better
Re: Tank Repair
03 May 2009 16:44
#287574
I repaired a couple of pin holes in an auxiliary fuel tank for our combine last summer with POR-15. They provide a strip of gauze fabric that helps hold the sealer over the area. It worked great and the tank is completely sealed.
Nate
1979 KZ650 (Complete!)
1979 KZ650 SR (Sold!)
1979 KL250 (For sale)
1994 Bayou 400 (four wheel peel :D )
  • arai59
  • arai59's Avatar
Re: Tank Repair
03 May 2009 16:54
#287577
I have them leaded up at a local radiator shop. Lower heat and less chance of a blow out from welding. Brazing is about the same. Make sure the inside is clean. Acid wash with a good rinse works well. A por-15 coating also helps.
  • CTait
  • CTait's Avatar
Re: Tank Repair
03 May 2009 16:59
#287579
needs to be purged out with argon or nitrogen to prevent fires, after its properly cleaned. thats a contiuous purge not just filling it up too.
Riding: 79 KZ650
  • GalwayZ
Re: Tank Repair
04 May 2009 06:46
#287764
lots of tips - thanks - when you say lead i assume you mean lead solder ?
