KZ1000 Side cover
Re: KZ1000 Side cover
20 May 2009 02:29
#292820
Hitchpin clip sometimes works where one of the sidecover tabs is accessible enough. :)
20 May 2009 02:35 - 20 May 2009 02:39
#292821
I believe this remedy was contributed by locozuna :cheer: in an earlier thread ---
Here's the sidecover showing ample tab clearance so that no hole need be drilled through the external surface of the sidecover. [See wire attachment in following post]
Last edit: 20 May 2009 02:39 by Patton.
20 May 2009 02:37 - 20 May 2009 02:38
#292822
Good Luck! :)
Last edit: 20 May 2009 02:38 by Patton.
  • athlonwirez
  • athlonwirez's Avatar
21 May 2009 06:45
#293047
The hitch pin sounds like a great way to go. I'll be doing that soon.
1978 LTD Partial Restoration in Process. (Do not have orginal exhaust)
  • flaviote
  • flaviote's Avatar
25 May 2009 18:14
#293986
I've lost one side cover in my KZ550 too!.
That's a very simple and effective way to keep them safe :D.
Great Idea!. Will do it.
  • gnfreak
  • gnfreak's Avatar
25 May 2009 18:24
#293991
after seeing a par of classic side covers go for $160 on ebay i did the drill and cotter pin route. i went to the tackle box and used a couple of ss leaders and looped the loose end around the frame. the covers can come off a little but then they hang there. assembly requires pushing the leader back thru the gromment.
Normal, IL
1980 KZ1000-G1 Classic - Sold
  • Mikesz28lt1
  • Mikesz28lt1's Avatar
30 May 2009 16:16
#295115
You can check ebay, or I found a side cover for my 82 LTD at a place called BB Cycle in Mansfield ohio, they have tons of parts for old bikes, and there prices are reasonable. bbcyclesalvage.com
  • luv my KZ1000LTD
  • luv my KZ1000LTD's Avatar
01 Jun 2009 22:24
#295672
Same problem couple years ago. Bought unfinished side cover from Redline Inc. Had it painted and replaced. Very costly, but well worth it. However, now I have secured them with zip ties. Cheap and easy to take on and off when needed. And obviously, replaced the groumets. That goes without saying.
Love My LTD,
Bustamonte Bill
