Tell me if this is a stupid painting idea...
  • meNmyKZ
  • meNmyKZ's Avatar Topic Author
03 Apr 2009 11:57
#278080
Alright, I have couple questions here. First is, what is the best way to remove old pin striping? It looks horrible on my bike and needs to go.
Ok, another thing. I want to repaint the tank and tail. Eventually even the frame once I have the proper skills to rip it down that far. What I am wondering is if you can use spray paint, sprayed right out of the can. If I prime it (also with primer spray paint) and take my time, you can get it to look pretty decent right? I am by no means trying to make this a show bike. Probably gonna lean somewhat toward "cafe" style. Very minimalist, just the basics.
Also, can you get decent clearcoat in spray paint form?
Thanks for all reply, I appreciate it.
  • Mark Wing
  • Mark Wing's Avatar
Re: Tell me if this is a stupid painting idea...
03 Apr 2009 12:45
#278092
Yes if you take your time it will look OK. It will be easy to mess up with gas though.
Mark
Yorba Linda Cal.
  • meNmyKZ
03 Apr 2009 12:51
#278093
Thanks Mark, appriciate the input. Painting is a bit down the road... but i need the pinstriping off soon. How about how to do that? Thanks again for responding
  • anarki650
  • anarki650's Avatar
03 Apr 2009 13:00
#278095
Not real sure about removing the pin striping, but if you use rattle can to paint warm up your paint cans by letting them soak in a pan of warm water for about 20-30 minutes before spraying. Makes the paint flow WAY better and helps avoid the crappy spray patterns you can easily get out of a rattle can.
09 Kawasaki ER6n
77 kz650b1 cafe rebirth project
"Being shot out of a cannon will always be better than being squeezed out of a tube, that's why God made fast motorcycles..."
Dr. Hunter S. Thompson
Omaha NE
  • JMKZHI
  • JMKZHI's Avatar
03 Apr 2009 13:12
#278100
The paint & pinstripes on my bike were in poor condition, so I sanded the tank & sanded off the pinstripes. The stock paint is tough as nails, so it didn't seem worth the trouble to chemically strip it. I painted it w DupliColor paint, but it isn't fuel resistant at all. ChuckHawks.com has a good, easy to read & follow how_to - Harley Paintin' for the Underfunded & Underskilled.
The green tank was done w the rattlecan paint.
  • meNmyKZ
03 Apr 2009 13:25
#278104
Excellent. Thanks for all the info and thats a cool tip to heat up the paint... never would have thought of that one. Much appriciated for all the posts
  • MFolks
  • MFolks's Avatar
03 Apr 2009 13:34
#278106
www.eastwood.com sells a pin striping tool that uses a fine abrasive wheel with a slow turning drill to buff off the stripes.
  • PLUMMEN
  • PLUMMEN's Avatar
03 Apr 2009 14:07
#278111
thats my suggestion also.B)
  • Old Man Rock
  • Old Man Rock's Avatar
03 Apr 2009 15:28
#278146
Can paint yes ok....
Can clear coat HELL NO!!!!
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • wizardofoz
  • wizardofoz's Avatar
03 Apr 2009 15:40
#278150
if the pin stripes / decals are the stick on type, just warm them up with a hairdrier, they will come right off.
