rear fender
- GalwayZ
rear fender
24 Mar 2009 03:06
Am i correct in thinking the b2 has a shorter rear fender than the b1 - if so are they interchangeable?
- StreetfighterKz
Re: rear fender
24 Mar 2009 04:35 - 24 Mar 2009 04:36
I think you need to specify which model of bike you are talking about as a lot of models have the B1 and B2 versions.
Kz650, Kz750, Kz1000, etc
Later, Doug
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
Last edit: 24 Mar 2009 04:36 by StreetfighterKz.
- RonKZ650
Re: rear fender
24 Mar 2009 06:47
The 400,440,550,650,750,1000,1100 Kawasakis, any of these models the rear fender is the same for the CC in a B1 and B2, so I'd say whatever bike you have chances are the fender is not shorter on the B2 than a B1 of the series.
- GalwayZ
Re: rear fender
24 Mar 2009 07:30
z 650 - ive seen early photos of both models and in some the b2 seems to have a shorter fender - the bottom of mine finishes up pretty much in line with the back axle. Something shorter would look a lot better i think.
- StreetfighterKz
Re: rear fender
24 Mar 2009 08:43
AHA! I see where the confusion comes from. Since you called it a Z650, I assume you're in Europe? If so the European models of the Kaws tend to have longer fenders than the US models. It's not really a difference in B1 and B2 models but where the model was made for.
I'd say the fenders should be swappable since the frames shouldn't change.
Later, Doug
Later, Doug
1979 z650 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
- GalwayZ
Re: rear fender
24 Mar 2009 10:31
Thanks doug - at least now i know where to look for a shortie - i dont want to go as far as fenderless but the shorter us spec fender is a lot neater and better looking.
cheers.
cheers.
- rstnick
Re: rear fender
24 Mar 2009 10:34
Canadian models also had the shorter fenders.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
- GalwayZ
