Rust treatment & prevention - pic
  • JMKZHI
  • JMKZHI's Avatar Topic Author
17 Mar 2009 16:03
#272815
Here's a pic of a couple of parts.
They were cleaned & polished prior to treatment; the rust was scrubbed w a brass kitchen brush. The fender was sprayed w bar-b-que grill paint on the underside & topcoated w 3M auto undercoating. The tail lite bracket was painted w wheel paint - the silver is actually a good match; although it doesn't matter since the painted area is kinda hidden.
I've done a number of parts this way to treat & prevent rust. It seems to work well.
  • timebomb33
  • timebomb33's Avatar
Re: Rust treatment & prevention - pic
18 Mar 2009 08:49
#273062
looks good i always paint the underside of my fenders too i ride in the dirt and gravel alot in the summer i never thought of using undercoat good idea that would stop every rock from coming up thru and damaging the chrome
I THINK MY POWERBAND BROKE
  • JMKZHI
18 Mar 2009 09:57
#273076
I did the front fender a couple of years ago w the same stuff (3M 08881 Rubberized Undercoating), but I sprayed a rust fixer as a pre-treatment, instead of bar-b-que paint as was used on the rear fender in the above pic.
The muffler cover was sprayed w bar-b-que paint; the muffler tip was done w engine paint.
  • burkmanofgod
  • burkmanofgod's Avatar
  • 1981 KZ750H2
18 Mar 2009 11:17
#273104
Beautiful job the parts look great.
1981 Kawasaki 750 LTD
2006 Honda Shadow 1100 Spirit
  • JMKZHI
18 Mar 2009 11:53 - 18 Mar 2009 19:21
#273115
Thanks. The parts were in fairly good shape, so it didn't take much effort. I hate rust.
Rear wheel w bar-b-que paint to treat the rusty spoke nipples.
Last edit: 18 Mar 2009 19:21 by JMKZHI.
  • JMKZHI
18 Mar 2009 11:56
#273117
750 exhaust w one treated muffler cover removed.
  • JMKZHI
18 Mar 2009 12:08
#273120
The front fork lowers were done several years ago w the same silver wheel paint as the tail lite bracket (DupliColor). The paint now has some fine cracking but has otherwise held up well.
  • H2RICK
  • H2RICK's Avatar
  • Is this a fun bike, or what!!!
18 Mar 2009 13:41
#273134
You've done some nice work there, JMKZHI.....especially those forks. I wonder if a topcoat of clear might have stopped the silver from cracking??
I've done a number of fenders with the undercoat trick. It's great because the petroleum base of the undercoat stops further rusting of any little spots I might have missed in the initial cleanup.
KZ650C2 Stock/mint. Goes by "Ace".
H2A Built from a genuine basket case. Yes,it's a hot rod.
GT550A Stock/mint. Pleasant stroker.
2006 Bandit 1200S for easy LD rapid transit
Various H2 projects in the wings.
  • JMKZHI
18 Mar 2009 19:19 - 25 Mar 2009 12:35
#273220
The forks were topcoated w DupliColor High Performance clear wheel coating - I'd forgotten that. I guess the tubes flex? As for the undercoating being petroleum based & rust inhibitive, I didn't think about that: maybe I could've skipped the bar-b-que paint? - I sorta use it as a rust treatment & primer.
For things like an engine cover, I use brake caliper or engine paint. Clean & polish, apply a very light amount of grease to the raised areas, mask the perimeter, then spray. Afterwards, wipe off the lettering n such. Fast n easy.
Last edit: 25 Mar 2009 12:35 by JMKZHI.
  • WABBMW
  • WABBMW's Avatar
  • Let The Good Times Roll !
18 Mar 2009 19:31
#273227
Beautiful work as always JMK.
Bill Baker
Houston, Texas
1982 KZ650 CSR
2008 Yamaha FZ1
2006 Yamaha FZ1
1977 Honda Supersport 750 four (sold)
1984 Honda Nighthawk 650 (sold)
  • bowtie39
  • bowtie39's Avatar
21 Mar 2009 21:36
#274077
Not really a rust question or suggestion, but still about paint or touch-up.
How about the white lettering on the controls. The white has vanished on the starter switch side.
Any suggestions on applying some white in there?
22 Mar 2009 05:04
#274152
Hello bowtie39! :)
We're glad you're here! :cheer:
One option is after clean and dry, use toothpick or whatever to fill lettering depressions with white enamel.
There's likely some slop-over, but leave it alone for awhile until the enamel dries a little.
Dampen a thin smooth white cloth such as hankerchief material with paint thinner or mineral spirits.
Wrap the damp cloth tightly around a popsickle stick or tongue depressor or whatever.
Gently wipe over the lettering to remove the excess slop-over enamel while leaving enamel inside the filled lettering depressions.
An unsure if this is exactly how Picasso would do it. :lol:
Good Luck! :)
