Rust treatment & prevention - pic
- JMKZHI
17 Mar 2009 16:03
Here's a pic of a couple of parts.
They were cleaned & polished prior to treatment; the rust was scrubbed w a brass kitchen brush. The fender was sprayed w bar-b-que grill paint on the underside & topcoated w 3M auto undercoating. The tail lite bracket was painted w wheel paint - the silver is actually a good match; although it doesn't matter since the painted area is kinda hidden.
I've done a number of parts this way to treat & prevent rust. It seems to work well.
- timebomb33
Re: Rust treatment & prevention - pic
18 Mar 2009 08:49
looks good i always paint the underside of my fenders too i ride in the dirt and gravel alot in the summer i never thought of using undercoat good idea that would stop every rock from coming up thru and damaging the chrome
I THINK MY POWERBAND BROKE
- JMKZHI
18 Mar 2009 09:57
I did the front fender a couple of years ago w the same stuff (3M 08881 Rubberized Undercoating), but I sprayed a rust fixer as a pre-treatment, instead of bar-b-que paint as was used on the rear fender in the above pic.
The muffler cover was sprayed w bar-b-que paint; the muffler tip was done w engine paint.
- burkmanofgod
- 1981 KZ750H2
18 Mar 2009 11:17
Beautiful job the parts look great.
1981 Kawasaki 750 LTD
2006 Honda Shadow 1100 Spirit
- JMKZHI
18 Mar 2009 11:53 - 18 Mar 2009 19:21
Thanks. The parts were in fairly good shape, so it didn't take much effort. I hate rust.
Rear wheel w bar-b-que paint to treat the rusty spoke nipples.
Last edit: 18 Mar 2009 19:21 by JMKZHI.
- JMKZHI
18 Mar 2009 11:56Please Log in or Create an account to join the conversation.
- JMKZHI
18 Mar 2009 12:08
The front fork lowers were done several years ago w the same silver wheel paint as the tail lite bracket (DupliColor). The paint now has some fine cracking but has otherwise held up well.
- H2RICK
- Is this a fun bike, or what!!!
18 Mar 2009 13:41
You've done some nice work there, JMKZHI.....especially those forks. I wonder if a topcoat of clear might have stopped the silver from cracking??
I've done a number of fenders with the undercoat trick. It's great because the petroleum base of the undercoat stops further rusting of any little spots I might have missed in the initial cleanup.
KZ650C2 Stock/mint. Goes by "Ace".
H2A Built from a genuine basket case. Yes,it's a hot rod.
GT550A Stock/mint. Pleasant stroker.
2006 Bandit 1200S for easy LD rapid transit
Various H2 projects in the wings.
- JMKZHI
18 Mar 2009 19:19 - 25 Mar 2009 12:35
The forks were topcoated w DupliColor High Performance clear wheel coating - I'd forgotten that. I guess the tubes flex? As for the undercoating being petroleum based & rust inhibitive, I didn't think about that: maybe I could've skipped the bar-b-que paint? - I sorta use it as a rust treatment & primer.
For things like an engine cover, I use brake caliper or engine paint. Clean & polish, apply a very light amount of grease to the raised areas, mask the perimeter, then spray. Afterwards, wipe off the lettering n such. Fast n easy.
Last edit: 25 Mar 2009 12:35 by JMKZHI.
- WABBMW
- Let The Good Times Roll !
18 Mar 2009 19:31
Beautiful work as always JMK.
Bill Baker
Houston, Texas
1982 KZ650 CSR
2008 Yamaha FZ1
2006 Yamaha FZ1
1977 Honda Supersport 750 four (sold)
1984 Honda Nighthawk 650 (sold)
Houston, Texas
1982 KZ650 CSR
2008 Yamaha FZ1
2006 Yamaha FZ1
- bowtie39
21 Mar 2009 21:36
Not really a rust question or suggestion, but still about paint or touch-up.
How about the white lettering on the controls. The white has vanished on the starter switch side.
Any suggestions on applying some white in there?
22 Mar 2009 05:04
bowtie39 wrote:
Hello bowtie39!
We're glad you're here!
One option is after clean and dry, use toothpick or whatever to fill lettering depressions with white enamel.
There's likely some slop-over, but leave it alone for awhile until the enamel dries a little.
Dampen a thin smooth white cloth such as hankerchief material with paint thinner or mineral spirits.
Wrap the damp cloth tightly around a popsickle stick or tongue depressor or whatever.
Gently wipe over the lettering to remove the excess slop-over enamel while leaving enamel inside the filled lettering depressions.
An unsure if this is exactly how Picasso would do it. :lol:
Good Luck!
Hello bowtie39!
Good Luck!
