polishing..look at this
  • doc
  • doc's Avatar Topic Author
28 Feb 2006 16:28
#27173
MY new to me 82 kz1000 ltd had a lot of stains ect on the aluminum all over the bike, Before i got out the rouge and the dremmel i decided to try a product named Gords aluminum polish...i am pretty happy with the results, took out stuff other polishes i tried couldnt even touch.
  • doc
Re: polishing..look at this
28 Feb 2006 16:31
#27176
here is the before
  • doc
28 Feb 2006 16:32
#27178
after
  • doc
28 Feb 2006 16:33
#27181
barly any work, took less than 2 hours
  • kawtoy
  • kawtoy's Avatar
28 Feb 2006 16:35
#27183
Looks darn good. Anytime we can get good results with little work, we will listen. Can you get an identical pic like the first one so we can get a better comparison? Thanks
Harley Davidson- Turning gas into noise without the harmful affects of horsepower for over 100 years.
  • doc
28 Feb 2006 18:21
#27205
i am out of town on buisness, but i will as soon as i get back on saturday. I wish i would have taken pics of the fork tubes, it really cleaned those babies up good. I did three coats, first two with super fine steel wool, and last one with just a red shop rag.
here is the other side after 1 coat(forgot to take a before)
  • doc
28 Feb 2006 18:22
#27206
other side after 3 coats(45 mins work allowing for drying time)
  • KevZ
  • KevZ's Avatar
03 Mar 2006 10:18
#27868
Looks pretty good! Where do you get Gord's aluminum polish?
  • kawasakikid38
  • kawasakikid38's Avatar
04 Mar 2006 15:43
#28221
looks good man, did you ever try blue magic? that stuff is unreal.
  • wireman
  • wireman's Avatar
04 Mar 2006 16:30
#28239
ive allways had great luck with mothers aluminum polish any kind of polish is going to take a lot of rubbing ive got piles of old t-shirts i use just keep using a clean spot on the rag your using as long as youre getting black stuff on your rag keep on rubbing.be very carefull using a dremel to polish aluminum parts ,i spent a few hours the other day filing and block sanding a lower fork leg to get the waves out that someone put in there polishing them with a dremel.:whistle:
Post edited by: wireman, at: 2006/03/04 19:54
  • doc
05 Mar 2006 20:13
#28592
i tried mothers and it did not get as much out as gords did, and the work with gords was easier. i have never tried to use the blue magic. gordsaluminumpolish.com/index.html is the website for gords. Unfortunatly, i decided i was going to drive her up to arkansas, and about 200 miles into the trip i am pretty sure i blew a piston ring. Back into the shop she goes.
  • fergyfer
  • fergyfer's Avatar
09 Mar 2006 14:45
#29666
I just spent several hours doing the same thing basically, looks like on the same engine. My sides were tarnished badly, and there was a layer of laquer covering a big part of each side cover. I used paint stripper to remove the laquer and then 3m rubbing compound and then mothers billet polish with a buffing attachment on my drill. Still a ways to go, but a major improvement.
Before...
