A few things ... updated with a few more things
  • quader98
  • quader98's Avatar Topic Author
28 Feb 2009 21:34 - 31 Jul 2009 18:29
#268827
1- i want to cut down my front fender and was wondering if anyone has pics so i can kinda judge how much i should cut off
2- i haven't worked much in the last few months,I'm working enough to support my family but not much for anything else.i need body work and paint and was gonna send everything out but now it seems like i have to try and do it myself.i have never ever never done any type of body work so was hopeing that someone knew of a sight that had videos on how to do it.everywhere i go they show you 2 minutes of how to and 3 minutes of how you can buy the dvd and learn how to do it like the pro's blah blah blah,i would like something that is a freebeee
Ernie from central jersey
82 GPZ 750 R1
looking to part out my 81 KZ750E2
Last edit: 31 Jul 2009 18:29 by quader98.
  • quader98
Re: A few things
01 Mar 2009 18:24
#269072
thanks for the links,thier great :) any links for vids?
anybody have any pics of your bobbed fenders?
82 GPZ 750 R1
  • PLUMMEN
  • PLUMMEN's Avatar
Re: A few things
01 Mar 2009 20:02
#269101
heres a before shotB)
  • PLUMMEN
  • PLUMMEN's Avatar
Re: A few things
01 Mar 2009 20:04
#269102
heres an after shot of same fender with around 4" off each end and replated B)
  • quader98
Re: A few things
02 Mar 2009 05:39
#269188
yea 4 inches looks good thanks
82 GPZ 750 R1
  • franknsr
  • franknsr's Avatar
Re: A few things
02 Mar 2009 05:55
#269191
Wow Plummen, you look a lot younger than I expected....not at all like the guys on this board described. ;)
Formerly CSRchopper
1991 KZ1000P
Gone but not forgotten
1986 ZG1000
1982 650 CSR -shoulda kept this one-
Lisle Illinois, USA
  • BSKZ650
  • BSKZ650's Avatar
Re: A few things
02 Mar 2009 09:10
#269219
And he has HAIR TOO,,,lmao:woohoo: :woohoo:
77 ltd1000, current rider
76 kz900, just waiting
  • quader98
Re: A few things
02 Mar 2009 11:25
#269242
HEY,i too am folicly challenged :laugh: :laugh: :laugh:
82 GPZ 750 R1
  • wiredgeorge
  • wiredgeorge's Avatar
Re: A few things
04 Mar 2009 06:43
#269592
If you have a compressor, the problem isn't knowing how to paint, it is having the skill to paint. I know basically HOW to do what needs to be done but laying on clear coat without it being too thin or turning into a puddle is more practice than anything else. The base coat actually isn't terrible to get right and you can sand and touch up if you mess up some. Practice on your trash can a bunch with the clear until you can lay it on in the correct thickness. I think the MAIN advantage the pro has is those zillion practice strokes before he gets to your work. ALSO... couple of thoughts... Prep is the key to making the job look good. Most of us can't sit still long enough to do a good job sanding filler and the old surface. Next thing is to make SURE you take off your gas cap and paint up onto the filler neck. If you don't, the paint will separate in that area and come off around the gas cap. Once you have dried clear and this happens, it is hard to sand the area and fix it... that is a high-skill chore so it is best to get the paint on in that area correctly the first time. Last thing is to check for leaks BEFORE doing any body work... leaks will be in the form of pin holes. It is easiest to pressure test the tank... they tend to rust on the seam on the bottom and lower side just above the seam. A pinhole WILL show up after paint as a bubble in your new paint job will appear. JB Weld or brazing work fine to fix any pinholes.
  • quader98
Re: A few things
31 Jul 2009 18:36 - 31 Jul 2009 18:40
#310614
well i decided to slowly tackle the paint myself this is where im at right now
82 GPZ 750 R1
Last edit: 31 Jul 2009 18:40 by quader98.
  • PLUMMEN
  • PLUMMEN's Avatar
Re: A few things
31 Jul 2009 18:42
#310616
that famous 1st shot was from 1979! :laugh:
