Fabricating hardware for a full fairing???
  • Heavy- Z
  • Heavy- Z's Avatar Topic Author
20 Feb 2009 22:09
#266685
Any tips on fabricating fairing brackets for a full size vintage fairing.
A La parisienne copy from mad max jim goose bike and toecutters
www.toecutterz.com
  • timebomb33
  • timebomb33's Avatar
Re: Fabricating hardware for a full fairing???
20 Feb 2009 22:15
#266688
can't help you but thanks for the info on the fairing i bet thatwould look good with a tracy body
I THINK MY POWERBAND BROKE
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
21 Feb 2009 10:45 - 21 Feb 2009 10:48
#266818
All depends on where the mounting points of the fairing are.
On the Rickman fairing I have, it has two mounting points just above the headlight in the Dash area that is is a horizontal mounting point. The dash is horizontal, and the two bolts go up and down vertically. This rests on the fairing bracket, seen in the right of this picture:
The bracket has an angle piece of metal that clamps to the steering stock/post, and then a single bar coming off the angle piece to the fairing frame that supports the headlight independantly.
The angle piece is bolted to two brackets that fit over the gas tank frame mounts:
The lower part of the fairing uses the two brackets in the top picture, left side. They mount to the rear engine mount bolts in my case.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
Last edit: 21 Feb 2009 10:48 by rstnick.
  • eruhf
  • eruhf's Avatar
06 Mar 2009 13:35
#270063
1977 KZ1000
1980 KZ1000 LTD - '76 900 motor
