Painting monoshock?
- kawtoy
Painting monoshock?
26 Feb 2006 18:16
I have a monoshock that I need to make look better. Should I paint, powdercoat or what? I was also think about spraying it with a rubber coating or a rhino liner type coating. Any ideas? Thanks
Harley Davidson- Turning gas into noise without the harmful affects of horsepower for over 100 years.
- wireman
- kawtoy
Re: Painting monoshock?
26 Feb 2006 19:20
It is a monoshock from a FZ700 that is going on my BC350 project. It is red and flaking apart right now. I am worried about what material will hold up to the flexing that the shock will see.
- wireman
26 Feb 2006 19:35
i wasnt sure if you were talking about shock or swingarm.if its a shock disassemble it as much as possible including spring.clean it up really good and paint it maybe have spring and adjustment collar plated if youre into that before reassembly.goodluck,happy wrenching!
Post edited by: wireman, at: 2006/02/26 22:35
- kawtoy
26 Feb 2006 19:48
How the heck you take one of these apart? Do I need a spring compressor?
- wireman
26 Feb 2006 19:58
post a picture if you can so we can see what kind of shock it is and give you some ideas.
- KzJim
27 Feb 2006 08:48
YES use a pring compressor! the spring could take yer head off if not done properly.
Powder coat it! im doing a set of Mulhollands for a guy, ill post pics when im done.
Naiveté in grownups is often charming, but when coupled with vanity, it is indistinguishable from stupidity.
Tis better to remain silent and thought a fool - than to speak up and remove all doubt.
Did ever think that maybe you've been doing it wrong all these years?
- kawtoy
27 Feb 2006 17:22
Here is the shock. Pretty rough huh? So how do I get it apart. I have never taken a shock like this down totally. Thanks
- wireman
27 Feb 2006 19:52
wow that is differant!does it look like it has a c-clip that is held in by the spring ?:whistle:
- KzJim
02 Mar 2006 11:41
- BARNEYHYPHEN
02 Mar 2006 12:21
KzJim, Did you do those yourself. They look tremendous.
- KzJim
03 Mar 2006 07:57
Barny... sure did.. i have my own PC'ing biz. those are from and older dirtbike that is being restored.
Post edited by: kzjim, at: 2006/03/03 11:49
