GPZ style fairing
- bigpappab
GPZ style fairing
05 Feb 2009 09:18
Assuming I get the charging issue (lack of) fixed on the bike, I thought about getting rid of the Vetter fairing and changing to a GPZ style on my 82 KZ1100.
Are there any kits for this conversion or am I going to piece it all together? I found the fairing butwhat about the headlight and brackets?
Thanks
Thanks
- MFolks
Re: GPZ style fairing
05 Feb 2009 11:18
Try at:
1. www.redlinecycle.com
2. www.sudco.com
3. www.vintagecyclepart.com
4. www.kzzone.com
5. www.partsnmore.com
6. www.reproductiondecals.com
7. www.z-power.co.uk (British Kawasaki website)
8. www.zpower.com.au (Australian Kawasaki website)
9. www.japparts.com (Dutch Kawasaki website)
10. www.crc2onlinecatalog.com (Salvage website)
11. www.z1enterprises.com
12. www.americanclassix.com
13. www.babbitsonline.com
14. www.bornagainbikes.net (Salvage yard)
15. www.classickawasaki.se (Swedish Kawasaki website)
16. www.kz1000r.com (Website for ELR Kawasaki's)
2. www.sudco.com
4. www.kzzone.com
- MFolks
05 Feb 2009 14:11
I've got a PDF parts file on the 82 GPZ1100 B2 on my computer. So if you need some numbers let me know.
Some fairing brackets are:
11036-1349 Bracket L.H. (1 each)
11036-1350 Bracket R.H. (1 each)
11036-1439 Bracket (2 each)
These will attach the fairing to the handle bars.
I'm trying to locate the lower attachment part #
- parkingpuckguy
05 Feb 2009 15:14 - 05 Feb 2009 15:15
You can try these too........
www.airtech-streamlining.com/kawiz/ZX550GPZ1980-82.htm
www.airtech-streamlining.com/kawiz/ZRX111999-00.htm
www.airtech-streamlining.com/kawiz/ZRX120001-02.htm
Not exact matches but might help...
Last edit: 05 Feb 2009 15:15 by parkingpuckguy.
- Mcdroid
- Gone Kwackers
05 Feb 2009 19:06
So, what KZ1100 do you have?
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- bigpappab
05 Feb 2009 20:06 - 06 Feb 2009 21:01
mine's just an 82 A2...shaft drive model. It came with all the Vetter fairing and bags
Last edit: 06 Feb 2009 21:01 by bigpappab.
- gane
05 Feb 2009 20:23
B. GPZ style fairings are avail.in many guises, both in round and rect. h/l applications. for estetic value the stock is most appealing to me. but pricy. and unless stock require fabbing mounts. Parts Unlimited offers 2 sizes for round h/l's .Maier plastics an ABS stock replacement. Hope this helps. G
[img][/img] 1977 KZ1000A1
- bigpappab
05 Feb 2009 20:34
Any info helps
I have to get my charging problem fixed first. Got a new regulator coming this weekend.
- kano
- Not Another Bloody Limey!
06 Apr 2011 23:42 - 06 Apr 2011 23:44
sorry to dig up the past,
came across this old post while searching for some brackets my self.
there are 2 pt numbers for the upper left and right the kz1000r and the kz1000r2 (clocks are different sizes)
11036-1349 BRACKET-A,COWLING,LH (COWLING to upper tree)
11036-1350 BRACKET-A,COWLING,RH (COWLING to upper tree)
11036-1573 BRACKET-A,COWLING,LH (COWLING to upper tree)
11036-1574 BRACKET-A,COWLING,RH (COWLING to upper tree)
11036-1439 BRACKET-A,COWLING (top bracket to upper tree)
11036-1355 BRACKET-A,HEAD LAMP,B (COWLING to lower tree)
11036-1354 BRACKET-A,HEAD LAMP,B (HEAD LAMP tilt bracket)
if anyone has any gathering dust let me know.
Attachment P1050363Medium.JPG not found
Attachment BRMC7gBWkKGrHgoOKjcEjlLmPeBJ8yHF0YLQ_12.JPG not found
Attachment raggak_k-img600x450-1300270508ydarkh11495.jpg not found
Attachment DSC01106.JPG not found
Last edit: 06 Apr 2011 23:44 by kano.
- gengomerpyle
07 Apr 2011 13:46im also looking for one to replace my broken one(left side) for my 750r1kano wrote: sorry to dig up the past,
1982 GPZ750R1 ELR
1978 Honda CB750F SuperSport
1971 Honda CB750K
1970 Honda CL100 Scrambler
1971 Honda CB750K
- nobody0857
06 Feb 2012 03:44
I have a clone Gpz fairing in decent condition with the windshield. It will buff up nicely , no cracks scrapes or surprises. I also have all the mounting brackets including the headlight adjuster the mounts to the lower tree. as well as the upper pinch bolt I have a rectanguklar headlight assembly but not the bucket. You would also need a set of headlight ears with the mounting rubber. I just reluctantly sold my 82 GPZ1100 B2 to move back to Daytona after living in a Foreclosure, not mine but I was kicked to the curb like a non renter paying squatter. Anyway I need a Vetter windjammer mount for a n 82 Spectre 1100 Shaft. I have a Honda mount but with the GPZ oil cooler I added it will be a Pain to fab the whole thing together. Does anyone have a front Vetter mount out there. I have swapped headers from 1000's to 1100's even though the heads are different but so were the heads that designed all his shit. There are a lot of bolt on swapps that aren't in the book. Barry in FL Nobody0857@gmail.com
