HVLP setup
  • Virii
  • Virii's Avatar Topic Author
  • I like cheese
HVLP setup
01 Feb 2009 14:23
#261544
I've been looking for a decent HVLP gun and trying to find a reasonable compressor (as I don't have one) and came across this:
boston.craigslist.org/gbs/tls/1009927846.html
Lexaire HVLP Sprayer - $400 (Boston South End)
Used only once!!, Model LX-10 in perfect condition with long hose and adjustable nozzle spraygun, used only once and it shows!!
compare to new at over $900
It appears this would have everything I'd need, sans possibly some different nozzles for flake and such but I thought I'd ask. Does this seem like a good setup for a novice or would I be better served by purchasing a more expensive compressor but cheaper gun? (keeping in mind that I'm unlikely to do anything other than painting with the compressor)
In response to my brief questions to the seller, he stated:
This is the entire setup with gun, hose, and high volume low pressure sprayer. It’s like using an
airbrush if you ‘ve ever used one. I don’t’ have specs in particular.
The unit is perfect for the kind of work you plan to do as you can put the paint exactly where you want it with little to no overspray.
You also don’t need a spraybooth as a result of no overspray. Why don’t you call a motorcycle shop that could confirm
what I’m saying. I used to do hand oil finishes, but never had the patience or time for spraying. I used to sub it out as my
time was more profitably spent making the next piece of furniture. This is why I never really used it. I would try to find
someone who uses these and talk to them. Then, if it will fit the bill for you, come by. Good luck, Ron
Tess: 1977 KZ650-C1. VM24, 97.5/15/3rd. Dyna-S. Stock exhaust, coil mod performed, BR7EIX.
Angel: 1982 GPz550. Stock. DR8EIX.
  • KZErider
  • KZErider's Avatar
Re: HVLP setup
01 Feb 2009 21:05
#261640
All I've got is good to say about HVLP. I made a ton of money using a CapSpray unit I bought back in '85 or '86. Spray painted a lot of mini shutters, working shutters, doors, cabinets, etc, etc, etc...
I found that, even though there's not much overspray to have to deal with, there is quite a bit of fallout if you're "blowing and going".
Never got a chance to try one using automotive grade paint. I'll get to try some this week if the weather permits. I'll just be using a small gravity feed gun hooked up to a compressor with an in-line drier. Hope I don't mess up too bad. I know I'm in for a new experience.:)
81 KZ750E2(project), 81 KZ750E2(parts donor), 87 BMW K 75C - got it runnin, didn't care for it, holding for family member, 79 CB650(project) Nomad 1700, VStar 950
  • Virii
  • I like cheese
Re: HVLP setup
01 Feb 2009 21:34
#261647
I've heard the same from just about everybody I've spoken to and in looking through posts here, it seems there are some good recommendations but all of them appear to assume that you have a compressor (which I probably should...but don't as I've never really felt I had a reason. :( )
I can't really find any information on this particular model and the manufacturer's web site isn't really helping but from what I can assume, it's a "turbine" setup which sounds like it would really be far more than I need but work well for me from what I've read...although maybe there's more to the setup than I realize.
  • KZErider
  • KZErider's Avatar
Re: HVLP setup
02 Feb 2009 05:18
#261680
Actually, this set up most likely doesn't need a compressor since it has it's own source of low pressure air. You could check with a Sherwin-Williams paint store. I think they are dealers for this particular set up.
  • Kawickrice
  • Kawickrice's Avatar
Re: HVLP setup
02 Feb 2009 10:00
#261715
I to used the HVLP with a turbine in the late 80's early 90's. I used it for industrial coating and such and it did a great job for what I was doing.
One thing to keep in mind with automotive paint is that the turbine units create heat and that means you are shooting with hot air which can make automotive paint dry to quick. I am sure they have tried to rectify the problem but I am not positive. Most HVLP automotive guns do not use a turbine for these reasons, that means you need a big compressor to keep up with the cfm's that are required for these guns.
Depending on what you are shooting and how often should be your deciding factor. If you are spraying small things with automotive paint you might get away with it, but big jobs will create heat. This is just my 2 cents worth and is by no means the gospel. Good luck with your decision.
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
