Attaching sidecover badges
  • semerm
  • semerm's Avatar
Re: Attaching sidecover badges
22 Feb 2006 17:35
#25724
I took a soda can and cut out a small piece of aluminum. I then took a pocket knife and put a very small hole in the center of it and cut a 'X" over it (hole in center of x). Then I out it over the post and it holds the emblem very well!B)
  • hydrolazer
  • hydrolazer's Avatar
22 Feb 2006 19:11
#25753
try here,,,redlinecycles.com
\'79 kaw 1000 ltd
  • JMKZHI
  • JMKZHI's Avatar
Re: .
23 Feb 2006 12:57 - 03 Dec 2008 19:59
#25938
del
Last edit: 03 Dec 2008 19:59 by JMKZHI.
  • ran429
  • ran429's Avatar
  • Master of FREE rides!
23 Feb 2006 21:03
#26038
get a couple pressed out nuts (like press on ones which you removed) from the hardware, they have those thin one use ones which will come back off when or if you ever want to remove them again just by turning it backwards.
  • elr658
  • elr658's Avatar
17 Mar 2006 05:29
#31906
  • mysticwolf
  • mysticwolf's Avatar
17 Mar 2006 08:44
#31948
Got some good advise, but one thing I would do if I was you ( if you havnt already ) Put your side covers on, lift the seat and look down where the tabs come through ,mark with a nail, drill a whole and us cotter pins to hold them on, I lost one once, but got very luck and found it, also 3 years ago some ASS stoll both of mine write off my back porch in broad daylight, right after I got it painted. they cant now unless they brack them.
  • N0NB
  • N0NB's Avatar
  • Blue handles better
17 Mar 2006 13:32
#32008
Not sure if they're actually available, but I was doing a part check a while back and found that Ron Ayers had actual Kawasaki side cover emblems for the 650s priced for less than some reproductions I've seen.
- Nate >>
Nate
1979 KZ650 (Complete!)
1979 KZ650 SR (Sold!)
1979 KL250 (For sale)
1994 Bayou 400 (four wheel peel :D )
  • ran429
  • ran429's Avatar
17 Mar 2006 21:43
#32117
im going decals again, unless i learn how to use my airbrush while I paint the parts.
