Gun Kote 1200?
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
Re: Gun Kote 1200?
11 Feb 2009 12:14
#263840
Otakar, what cryteria determins which product to use. u said Prolane on carb bodies and gunkote on carb covers?
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • otakar
  • otakar's Avatar
Re: Gun Kote 1200?
11 Feb 2009 14:01
#263862
Gunkote is a much harder and much more refined finish. The way I would explain it would be this way. If it would be a part of your bike that you would otherwise polish like your side-covers, gas-cap, float-boles, brake-pedal,etc.etc, I would use Gunkote. If it is a part that you just want to look nice and not corrode but be very durable like, engine cases, cylinder block, cylinder head, valve cover, frame, swing-arm, fork down-tubes, etc. etc. I would use Polane. The only place this would be questionable would be the cylinder block and head. The reason for that is that there are draw backs and benefits to both. Polane covers better, the surface prep is not as critical. Gunkote on the other hand dissipates heat better because the film is thinner, but the surface prep must be perfect or it will peal in a hurry and than the remainder is almost impossible to remove with out sandblasting. The trick to painting an engine is to paint it metallic and not a solid color. The metallic flakes are in fact metal and they will help conduct the heat to the surface of the engine. this means, If you want to paint the engine black, add some metallic. Otherwise add a larger oil cooler to help dissipate the heat. I would also paint any brake components in Gunkote, for a couple of reasons. One, is that it is impervious to any kind of solvent or brake fluid. Two, because it dissipates heat better than any other finish with the exception of anodizing. Three, these components are quite small and therefore easy to cover completely and prep well. Anything I missed?
Otto
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
Re: Gun Kote 1200?
18 Feb 2009 09:38 - 18 Feb 2009 09:43
#265893
Thanks for that explanation Otakar.
Where does the Por15 fit in ?
This will be helpful for me when it is my time to repaint. B)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 18 Feb 2009 09:43 by mark1122.
  • otakar
  • otakar's Avatar
Re: Gun Kote 1200?
18 Feb 2009 11:52 - 18 Feb 2009 16:46
#265919
Por-15 "Rust preventative" and Por-15 Black are fantastic single component paints. Once they are cured out they are indestructible. On the other hand stay away from the "silver" it is absolute garbage. The black, weather the gloss or satin are fantastic paints for any stile of frame work. If you clean off the loose rust than use the black "Rust preventative" undercoat than the black over it, you will wind up with a better finish than factory, and many times more durable. I would say it stands only a little behind the Polane. The disadvantages are that it only has about a year or so shelf life, and oz. per oz. it is more expensive. On the other hand Polane you must buy in a Gallon, Por-15 you can buy as little as a Half pint. For frame work Por-15 can't be beat. I would stick to the BLACK and stay away from the metallics. For any engine work work GunKote or Aluminum Polane, for Steel or Ferris metals I would go with Por-15. Once again, if this is a highly decorative steel part or one with frction than go with GunKote. Take a look at the pictures of my GPz1100, the rear fender which was a rusted piece of Chromed steel was painted with Por-15 gloss black after I dunked it in Muriatic acid to remove the major rust, and than hit it with a Brilo pad before i painted it with POR-15 "Rust Preventative" and than black. same with the rear tail light/License plate mount.
Otto
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 18 Feb 2009 16:46 by otakar.
  • otakar
  • otakar's Avatar
Re: Gun Kote 1200?
18 Feb 2009 12:21
#265926
This instrument housing was Chromed plastic which was scratched up this was painted with Polane-T after scuffing with a brillo pad.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
Re: Gun Kote 1200?
18 Feb 2009 15:20
#265960
That helps. Thanks again Otto.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • switch
  • switch's Avatar Topic Author
  • 1981 KZ1000m CSR
Re: Gun Kote 1200?
20 Feb 2009 21:58
#266683
Just a friendly note to remind people that hijacking other people's postings is not a friendly thing.
I started this and I will end it. Now.
1981 KZ1000 M1 CSR
2004 Vulcan 1500 Classic (gone)
You do not have to believe everything you think!
  • KZQ
  • KZQ's Avatar
  • Administrator
  • Administrator
Re: Gun Kote 1200?
21 Feb 2009 08:07
#266771
Hi Switch,
Threaded discussions invite the participation of many members. While there have been a few posts that don't directly address "Gun Kote", I don't see anything disruptive or disrespectful in any of them.
I'd like to see you go with the flow.
KZCSI
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
  • otakar
  • otakar's Avatar
Re: Gun Kote 1200?
21 Feb 2009 08:22 - 21 Feb 2009 08:28
#266781
I do apologize about any unintended hijacking. If anyone has any questions about other finishes (including GunKote) please start another thread and I will be happy to answer them. After using most of these finishes for quite a few decades I will be happy to help.
Signing off of this post;
Otto
PS. The water-based ambient cure 1200 GunKote is not intended for prolonged exposure to the elements, it will not give you the corrosion resistance required, but it will hold up for a short while. Would I use it in the application you pictured? No. This is to answer your initial question.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 21 Feb 2009 08:28 by otakar.
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
Re: Gun Kote 1200?
21 Feb 2009 17:06
#266894
Sory Switch
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • switch
  • 1981 KZ1000m CSR
Re: Gun Kote 1200?
23 Feb 2009 20:44
#267652
As you wish, Jedi Master.
1981 KZ1000 M1 CSR
  • ran429
  • ran429's Avatar
  • Master of FREE rides!
Re: Gun Kote 1200?
19 Apr 2009 11:11
#283089
I am reviving this topic for my OWN knowledge.
Is this spray on gunkote finish sold in retail stores?
I am rebuilding a rifle and i want badly to use this easy finish, but refuse to pay shipping on a can of paint.
