Just got a 1000csr
  • pistolpete
  • pistolpete's Avatar Topic Author
Just got a 1000csr
01 Dec 2008 14:29 - 01 Dec 2008 14:43
#250217
This is not my first kz, but my first 1000, and I had two questions to start out with.
First is the seat, it seems like it is way too dished out (i am 6'4") and it has a travelcade cover. I am guessing that the previous owner cutout some foam while replacing the cover. Are there any other flatter style seats that swap, or should I just try to add some more foam?
Does anyone have pictures / opinions of this bike with more of a superbike handle bar setup? I hate the bullhorns.
Lastly, an elec question, am I right to assume that all mkII engine reg/rec & stators swap over?
Thanks
AJ
Last edit: 01 Dec 2008 14:43 by pistolpete.
  • cnyl
  • cnyl's Avatar
Re: Just got a 1000csr
01 Dec 2008 14:39 - 01 Dec 2008 14:46
#250219
Hi ya,
I'm working on an 82 CSR1000. I'm going with drag bars instead of superbike bars. There's already a 4 into 1 exhaust on it so i'm re jetting and going with pods. I'm dropping the front end a bit for better turn in. I can't wait to get it on the road.
Post up some pics.;)
1982 KZ1000 M2 CSR
North Port, FL
Check out my band
www.myspace.com/tukrhill
Last edit: 01 Dec 2008 14:46 by cnyl.
  • pistolpete
01 Dec 2008 14:55
#250222
No pics yet, but the bike is stock except for some case protectors, not that interesting right now. These bikes were meant to be modified!
  • Tommotbird
  • Tommotbird's Avatar
01 Dec 2008 14:57
#250223
If you don't like bullhorns, I don't think you would like these. They were fitted when I bought the bike & I think they are off a Harley but not too sure- the switch wires are routed inside the bars which is quite neat. Not decided whether to change them or not as they are quite wide.
Oh while I am here can anyone tell me the differences between the 1000CSR and the 1000LTD.
Triumph Thunderbird Sport
Triumph Legend
Lambretta SX150
Moto Guzzi V11 Sport
1981 KZ650CSR HI
KZ1100 A2 x 4
Z1 Classic
KZ1000 LTD K1 1981
KZ750 LTD H2 x 4
  • pistolpete
01 Dec 2008 15:03
#250224
I think there are more little things (gauges, etc..), but I believe the ltd had different cams (j cams) and carbs for 10 more hp, along with the tubless mag wheels.
01 Dec 2008 15:24
#250226
Harley handlebars are usually 1 inch as opposed to the stock 7/8" bars. I believe it would be difficult to adapt all the oem switch gear to a larger bar, and difficult to mount a larger bar in the 7/8" bar clamps.
Good Luck! :)
  • Tommotbird
01 Dec 2008 15:33
#250227
Hi Patton
That is another reason why the bars are so wide as 7/8" bar ends have been fixed to the 1" bars. Haven't measured the exact span width but they do feel pretty wide.
Triumph Legend
Lambretta SX150
1981 KZ650CSR HI
KZ1100 A2 x 4
Z1 Classic
KZ1000 LTD K1 1981
KZ750 LTD H2 x 4
  • kpier998
  • kpier998's Avatar
01 Dec 2008 15:43
#250230
One thing is that all the CSRs I ever saw had spoke wheels rather than the mags. If there was a difference in the engine, I didn't know it. My 82, LTD1000 owners manual states 92 horsepower iirc. They both had 85 mph speedometers. Maybe there was a difference in the color scheme...
  • pistolpete
01 Dec 2008 18:58
#250253
And the consensus on seats and charging system is?
Another thing i remember is that ltd's have elec tachs, csr mechanical
